3 members (Buckeye998, Jon G, 1 invisible),
118
Mod | | | Forums66 Topics128,091 Posts1,056,393 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#54426 01/04/2006 2:58 AM | Joined: Mar 2002 Posts: 553 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 553 | Well I finally upgraded my rear end.  I now have an open driveline. I removed the old torque tube differential and kept the rearend housing. I installed a pumpkin from a '55 half ton (fit right in perfect). I also changed the tranny to another sm420 that has an open rear yoke. Really came out nice!  I posted a bunch of pictures of the whole process on my Yahoo Photo Album . It's in the "rearend swap" file. I haven't been able to go for a longer cruise 'cause it won't stop raining. This opens up possibilities later on if and when I switch to a later model 6 cyl. motor. | | |
#54427 01/04/2006 3:59 AM | Joined: Jun 2001 Posts: 793 Bondo Artiste | | Bondo Artiste Joined: Jun 2001 Posts: 793 | John,
Awesome job Man!
It looks like it really turned out very well.
Also, nice photo album with great documentation of what you did to make it all happen.
I am assuming you were running 4:10 gears before the rear end swap? If so you will have to let me know if you really can feel a difference between the 4:10's and the 3:90's.
~ Phillip 1949 GMC Suburban - 10 year project 1952 Pontiac Chieftain Convertible straight 8 hydramatic 1945 GMC half ton truck - Driver- Sold 9-15-25 1946 Chevy COE - SOLD 1-5-26 BUH BYE CHEVY! 1959 GMC Half ton long bed NAPCO | | |
#54428 01/04/2006 4:19 AM | Joined: Sep 2002 Posts: 15 'Bolter | | 'Bolter Joined: Sep 2002 Posts: 15 | congrats!! I've been wondering if it's possible to just keep the 54 axle housing in place and replace the pumpkin and axles from a spare open driveline axle that just seems to have bolts in all the same places and same measurement here and there....and you did it first!!
now...where did that part go??
#54429 01/04/2006 9:53 PM | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | Nice job John, now you'll be able to get around town a little faster. Great to know you can just change out the pumpkin to retain the stock axle width. Great pictures. George | | |
#54430 01/04/2006 11:04 PM | Joined: Nov 2001 Posts: 481 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 481 | Nice photo documentation. I appreciate you sharing that information John. Looks like your son is a fine welder. | | |
#54431 01/04/2006 11:27 PM | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | very nice, man,, I wish I had just a little of the talent you guys have.............Fred Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | |
#54432 01/05/2006 3:00 AM | Joined: Mar 2002 Posts: 553 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 553 | Thanks alot guys. The weather finally cleared up so I went around the block a few more times this evening. Even though it's only a 3.90 rear end (the other was a 4.11), I can really tell a difference in speed. The tranny is way quieter too. My next step is to take it out on the main thoroughfare. I want to get it to top speed and see what she'll do....but I got to build alittle more confidence. | | |
#54433 01/05/2006 3:53 AM | Joined: Oct 2004 Posts: 235 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2004 Posts: 235 | Terrific job John. Thanks for sharing it.
Cheers mate
Bob | | |
#54434 01/05/2006 5:27 AM | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | Let me ask you guys a question. :confused: I have a 54 sedan closed drive line rear end under my 37 1/2 ton truck. I also have a 55 car rear end in my possession. Will a 55 car rear end pumpkin fit into a 54 car housing? Well, that's not really a truck question I guess, but does anyone know or know anyone who knows? It sure would make things easier for me as I work toward that T-5 installation, which, of course, requires an open drive line. Thanks, Joe
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | |
#54435 01/07/2006 3:54 AM | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Excellent job! Pictures are worth a thousand words they say and this is a perfect example. One question about removing the spring perches from the 55 axle. Can I do it with a grinder or does it need a cutting torch? Thanks. | | |
#54436 01/07/2006 4:08 AM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | John,
Wonderful pictorial..why did you R&R the perches. Did I miss something?
Stuart | | |
#54437 01/08/2006 4:25 AM | Joined: Mar 2002 Posts: 553 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 553 | oldblu40 - To remove the spring perches, I used an electric angle grinder with a 1/8" thick abrasive wheel. Carefully cut throught the weld and it'll pop right off.
automarc - The torque tube directly ties the rearend to the transmission. It is the only thing that keeps the whole rearend housing from rotating backwards when you step on the gas. So you remove the torque tube, the welded on spring perches keeps the rearend housing in one position. | | |
#54438 01/08/2006 3:56 PM | Joined: Jan 2001 Posts: 1,424 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,424 | Nice job is right on! I did the same to my '49 torque tube to '57 3.90 open drive line conversion. I use a '62 3 sp+od, .70 od x 3.90 = 2.73 final drive in od, around 2100 rpms at 65 or so.
~ Cosmo 1949 Chevy Half Ton Rocinante, like Don Quixote, he is awkward, past his prime, and engaged in a task beyond his capacities. "...my good horse Rocinante, mine eternal and inseparable companion in all my journeys and courses." ...Don Quixote, Cervantes "If you come to a fork in the road, take it."...Yogi Berra "Rudeness is the weak man's imitation of strength." ...Eric Hoffer
#54439 01/08/2006 4:24 PM | Joined: Feb 2005 Posts: 399 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2005 Posts: 399 | I'm looking at a truck with a 55 235, 4spd Saginaw, and a 55 Chev car rearend.. Does anyone know what the gears in that rearend might be? Thanks, Shoop | | |
#54440 01/10/2006 3:55 AM | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | I heard sometime ago, that a 1966 3/4 pumpkin will fit these old rearend housings. Does anyone know if this is true ?
Thanks,Tim 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
#54441 01/11/2006 10:40 PM | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | is the rear end housing the same on a 37 as it is on a 45??? I sure would like to know. I need to put a open line in a 37. Thanks for any info as if this is do-able to.....and ole Joe ask if the 55 open would fit into his 54 sedan closed rear end?? Now there is TWO questions, anyone one know? | | |
#54442 01/15/2006 6:56 PM | Joined: Sep 2002 Posts: 15 'Bolter | | 'Bolter Joined: Sep 2002 Posts: 15 | nice job!! why isn't the original spring setup suitable for open driveline?? would you elaborate?? I will eventually try the same project but I was going to leave the stock axle housing in place. thanks
#54443 01/15/2006 9:26 PM | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | Originally posted by bowtietim: I heard sometime ago, that a 1966 3/4 pumpkin will fit these old rearend housings. Does anyone know if this is true ?
Thanks,Tim Tim, that works for 3/4 and 1-ton trucks after '47. The Eaton H0xx axle was used until '72, '67-'72 trucks had a much more highway friendly 4.10 gear ratio available. | | |
#54444 01/18/2006 4:29 AM | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
#54445 01/22/2006 3:51 AM | Joined: Jan 2004 Posts: 210 Member | | Member Joined: Jan 2004 Posts: 210 | You used a '55. What years will work. I will be working on a 46 burb. Would like to have the info before I go to the junkyards. Thanks Jim | | |
#54446 01/22/2006 3:53 AM | Joined: Jan 2004 Posts: 210 Member | | Member Joined: Jan 2004 Posts: 210 | By the way, I learned a ton just looking at the picts!!! Jim | | |
