4 members (Oswald, GRNHydra, Napco Man, Greg_H), 98 guests, and 2 robots.
Topics128,030
Posts1,055,430
Members48,422
#543607 06/04/2009 10:20 PM
How do you remove the firewall electrical connector from a 61 apache. It's the connector located near the steering column.
Look under a couple of fuses and you should find a couple of through bolts holding it together,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
I think you're referring to the fuse panel.
I'm refering to the bulkhead connector, where the engine compartment wires connect to the cab. The bulkhead connector has a big rubber grommet around it and I don't know how to separate the two, so I can remove the connector.
The electrical connector has a lip around it that fits into a slot on the rubber grommet. The rubber is probably rock-solid with age. I worked the grommet & connector as an assembly out of the firewall and then had to carefully cut the gommet off the connector. New grommets were available for my 66. The quality isn't as good as the original so when I re-installed the connector & new grommet into the firewall I used some sealant around it.
Dave
66 GMC- father /son project with the "GMC KID"
36 Chevy PU- 4x4 lifetime project
64 Skylark- wife says its hers
dave64 #543943 06/05/2009 11:09 PM
Thanks Dave64. Did you remove it into the cab or into the engine compartment?
Unplug the two (upper should be hood lamps, lower is alternator/headlamp etc harnesses) connectors that attach to it under the hood then pull it back into the cab. The connector is part of the harness inside the cab.
Dave
