Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (homer52, Otto Skorzeny, Peggy M, frogfarmer), 150 guests, and 8 robots.
Topics128,281
Posts1,058,482
Members48,490
#543911 06/05/2009 9:06 PM
comp cams sold me a cust. cam grind for my 54 235 for heavy towing went in perfact same casting and all but went to put the lifters in and darned if they sold me the wrong lifters (to small od) they were for a reg. small blk chevy my six needs real large hyd. lifters. Napa says no go, anybody sell new hyd lifters for that 54 235 or know a part # for a set
Z
ZooKeeper
Unregistered
ZooKeeper
Unregistered
Z
The Summit Racing Online Store shows the have them.
THIS PAGE may also privide some info.
HERE's an eBay link for some.
And National Chevy sells them...joe
#543920 06/05/2009 10:01 PM
zookeeper the ones listed on summet are the small od lifters from comp cams there techs said they do not sell the large od lifters thats my cunundrum
You might check here.
I do have a queston. What did the engine originally come out of? That could make a difference in finding the right part. The reason I ask is that you mention that it's a hydralic cam engine, which leads me to beleive it's either a Passenger car w/Powerglide, or it's a '58-'62 block. The earlier blocks usd in trucks and std shift cars were mechanical cams, and were not drilled for hydralic lifters until '58.
Bill Burmeister
LONGBOX55 #543961 06/06/2009 12:00 AM
.... if its a later model go to Advance Auto. I "think" they can get them overnight in some cases.
the block is a casting 3837004 the stamping is 05I8776F56Z the lifter bores all have a galley running front to rear I hope that means its set up for hyd. lifters other wise I have been given wron info
also I think the hyd. lifter I need is .989 O.D. with a lenght of 2.3225 I think
Slickt #546499 06/13/2009 10:49 PM
Your engine is a 1956 "regular" 235 engine that uses solid lifters. What kind of lifters came out of the engine?? As far as I know hydraulics won't work in that block.
Slickt #547222 06/16/2009 7:01 PM
thanks you are the man! you gave me a good contact
Originally Posted by Slickt
