2 members (2-Ton, farmallb),
67
Mod | | | Forums66 Topics128,021 Posts1,055,352 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2009 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: May 2009 Posts: 47 | How do you remove the firewall electrical connector from a 61 apache. It's the connector located near the steering column. | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Look under a couple of fuses and you should find a couple of through bolts holding it together, Scott | | | | | Joined: May 2009 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: May 2009 Posts: 47 | I think you're referring to the fuse panel.
I'm refering to the bulkhead connector, where the engine compartment wires connect to the cab. The bulkhead connector has a big rubber grommet around it and I don't know how to separate the two, so I can remove the connector. | | | | | Joined: Mar 2005 Posts: 121 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 121 | The electrical connector has a lip around it that fits into a slot on the rubber grommet. The rubber is probably rock-solid with age. I worked the grommet & connector as an assembly out of the firewall and then had to carefully cut the gommet off the connector. New grommets were available for my 66. The quality isn't as good as the original so when I re-installed the connector & new grommet into the firewall I used some sealant around it.
Dave 66 GMC- father /son project with the "GMC KID" 36 Chevy PU- 4x4 lifetime project 64 Skylark- wife says its hers
| | | | | Joined: May 2009 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: May 2009 Posts: 47 | Thanks Dave64. Did you remove it into the cab or into the engine compartment? | | | | | Joined: Mar 2005 Posts: 121 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 121 | Unplug the two (upper should be hood lamps, lower is alternator/headlamp etc harnesses) connectors that attach to it under the hood then pull it back into the cab. The connector is part of the harness inside the cab.
