1 members (VicZ), 231 guests, and 2 robots.
Topics128,087
Posts1,055,976
Members48,430
#541885 05/29/2009 2:56 PM
Hey guys,
I'm planning on using electrolysis to get the rust out of my gas tank. The idea is to use a piece of rebar down inside of the tank as the positive electrode, and the tank itself as the submerging tank & negative electrode. Does anyone have any suggestions on a good gas tank coating/sealer to prevent it from coming back?
Some I've seen (including Redkote, Kreem) contain Methyl Ethyl Ketone and seem to me to be inferior, but the products from KBS Coatings and POR 15 don't. POR 15 I know is a Isocyanate Prepolymer which I think is similiar to superglue. Does anyone know what the difference is? Or better yet, Which is better?
Bryan
1954 3104 235 "AD" L-6 3-on-the tree
Y
Y Offline
I've used POR-15 tank sealer on 2 tanks over 2 years, so far so good. Eastman sells a sealer, just read and follow directions.
Ex Hall Monitor
Ex Hall Monitor
I've used several but never the POR-15 so can't speak to it. Of the coatings I've used I much prefer RedKote. As noted above, read and follow the directions.
Tiny #542568 06/01/2009 3:25 AM
the por15 i put in my 37 tank 9 years ago is holding up very well. I also put a coat of the regular por15 on the outside. So far so good. I'm sure others are out there and maybe just as good but I use what has worked well for me for years.
If your tank is very stong rosted, you should remove it mechanically before. E.g. with cullets inside fixed the tank on a cement mixer.
I also used the Por15 set in combination with Marine-Clean and Metal-Ready. It is very important to degrease the tank completely. Afterwards Metal-Ready dissolves the rost. Not before your tank is free of grease and dry, Por15 works very well. You can even repair little wholes in your tank if you put cloth over it.
'59 Apache
'67 Mustang
