| | | Forums66 Topics128,062 Posts1,055,857 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2009 Posts: 181 'Bolter | | 'Bolter Joined: May 2009 Posts: 181 | Hey guys,
I'm planning on using electrolysis to get the rust out of my gas tank. The idea is to use a piece of rebar down inside of the tank as the positive electrode, and the tank itself as the submerging tank & negative electrode. Does anyone have any suggestions on a good gas tank coating/sealer to prevent it from coming back?
Some I've seen (including Redkote, Kreem) contain Methyl Ethyl Ketone and seem to me to be inferior, but the products from KBS Coatings and POR 15 don't. POR 15 I know is a Isocyanate Prepolymer which I think is similiar to superglue. Does anyone know what the difference is? Or better yet, Which is better?
Bryan 1954 3104 235 "AD" L-6 3-on-the tree
| | | | | Joined: Feb 2006 Posts: 649 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 649 | I've used POR-15 tank sealer on 2 tanks over 2 years, so far so good. Eastman sells a sealer, just read and follow directions. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I've used several but never the POR-15 so can't speak to it. Of the coatings I've used I much prefer RedKote. As noted above, read and follow the directions.
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | the por15 i put in my 37 tank 9 years ago is holding up very well. I also put a coat of the regular por15 on the outside. So far so good. I'm sure others are out there and maybe just as good but I use what has worked well for me for years. | | | | | Joined: Sep 2007 Posts: 61 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2007 Posts: 61 | If your tank is very stong rosted, you should remove it mechanically before. E.g. with cullets inside fixed the tank on a cement mixer.
I also used the Por15 set in combination with Marine-Clean and Metal-Ready. It is very important to degrease the tank completely. Afterwards Metal-Ready dissolves the rost. Not before your tank is free of grease and dry, Por15 works very well. You can even repair little wholes in your tank if you put cloth over it.
'59 Apache '67 Mustang
