6 members (Otto Skorzeny, Woodcmiami, Gray_Ghost, Hanks custodian, 1955 1 Series, Forty9), 149 guests, and 9 robots.
Topics128,077
Posts1,056,031
Members48,433
#541201 05/27/2009 4:01 AM
Hey All,
I've been working on fixing a leak on my rear differential and found out I not only needed a new pinion seal (as expected), but that unless I installed a Speedi-Sleeve, my new seal would probably wear out in short time. The local shops want $50 for the one I need (99259), but believe it or not, Amazon.com has the same one for $31 - still not a deal, but better than $50! Plus, it's free 2-day shipping!
You'll need to find the part number on your own because Amazon can't help you there, but once you find it, type the part number and 'sleeve' in to the search box and you should find it. I hope that helps someone out there smile
Cory W. #541240 05/27/2009 8:03 AM
5 Online: Content
Sometimes you can lay a piece of wire in the groove where the seal goes. This will move the seal out the thicknest of the wire, so the seal can rub on a new spot on the yoke. Then you won't have to buy or install a speedi-sleeve. I quess I'm just cheap!!!!
Brian
1955.2 3100 Truck
55shaker #541319 05/27/2009 6:04 PM
Local parts houses have a different price code for different classes of customers and there is a huge difference in the price if they class you as a repair shop instead of a do it yourselfer.I check various sources before I buy anything unless I need it this minute. I just got 10 gallons of synthetic air compressor oil from WW Grainger who usually isn't cheap, but they have a free shipping promotion and the free shipping made it the most reasonable.
crenwelge #541374 05/27/2009 9:38 PM
Riding in the Passing Lane
Those sleevs are expensive for what they are but cheap for what they do. I agree with Cren, there are a lot of different prices out there.
1972 Chevy c10 Cheyenne Super
55shaker #541415 05/28/2009 12:19 AM
Thanks Brian,
If I hadn't already ordered the sleeve, I'd give your idea a try. Hopefully someone reading this later can learn they have other options than the local parts store on something like this.
Cory
Cory W. #541519 05/28/2009 5:07 AM
Are you serious about the price? I put one on my crankshaft where it comes through the timing cover. Its only paper thin metal and it was about $7.00. Unless we are talking about something entirely different.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
Sedgewick #541520 05/28/2009 5:14 AM
I stand corrected. I checked the NAPA catalog and that part number is indeed $49.95. However it is different in size and shape to what I referred to. The sleeve for the crankshaft is still priced below $10.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
Cory W. #541688 05/28/2009 11:37 PM
Originally Posted by Cory W.
Thanks Brian,
Cory
I think that would be a pretty clever trick(the wire one-MM) if you got away with it , but you would be replacing the seal sooner than if you did nothing. you can always replace the yoke with a new one.
perhaps the one by amazon are from china, so they would be a good place to purchase it from.
a proper brg est would stk all sizes and you may get a better price there.
you wouldn't be very happy if your boss went shopping tomorrow for someobne to do your job cheaper
ron
padresag #542303 05/31/2009 3:30 AM
It's SKF brand just like the ones at NAPA. The box says it is made by or for SKF in Illinois. No mention of China on the box, but I suppose it could have been. If you've ever seen one of these things, there is no way it costs more than $1 to make one, so even at $31, there's plenty of money being made, and I'd bet nearly all of it is being made right here in the US of A.
Cory W. #542560 06/01/2009 2:25 AM
I've seen the sleeves they sell at NAPA and they are VERY high quality, completely machined and ground to tolerances. I've also see the inexpensive ones and all they are is a stamped metal part.
I'd say the price for either is fair. You just have to decide how much it's worth to you.
Woody
Your Brother in Bolthood
My 1951 half-ton 'Ol Red
Door Art Collection
