| | | Forums66 Topics128,050 Posts1,055,641 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2005 Posts: 408 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 408 | I have a 1952 1/2 ton i am restoring and plan on putting in a 235. I have a 57 engine and don't know thw year of the bell housing. Do i need the 9 1/8 clutch or the 10 1/2 clutch. thanks for helping the uninformed. Paul | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | What's the flywheel measure out at? Scott | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Scott, seems to be a early 50's passenger car missing from your lineup, whaz happnin there???? Denny G.
Denny G Sandwich, IL
| | | | | Joined: Oct 2005 Posts: 408 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 408 | i have two flywheels to pick from. whitch to go?????? | | | | | Joined: Mar 2005 Posts: 92 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 92 | Which ever matches the engine and starter. If they both fit, go with the largest diameter disc, Scott | | |
