1 members (Hotrod Lincoln),
69
Mod | | | Forums66 Topics128,135 Posts1,056,423 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 175 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 175 | I am working on a project for a friend and he wants certain wheels on his truck we are going to put together and they are 6 lug and the truck is 8 lug, my question is, can I change axels and hubs or is it going to be the entire axel and everthing to the spindles. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | You'll have to change out the entire rear axle to get rid of the full floating hubs. You can also fit up 1/2 ton spindles to the front 3/4 ton axle if it's a straight axle.
As mentioned, year and make would be helpful. | | | | | Joined: Jan 2009 Posts: 175 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 175 | sorry it's a 62 and the doners are a 61 and a 62 | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | '61 and '62 IFS ('60 too) is an almost unique setup and it may be hard to find someone who has all the answers. I'd check part numbers for wheel bearings and ball joints and such to know how much of the front you need to swap. But if you have a 1/2-ton with good suspension parts it may be cheaper and less work to swap the entire IFS crossmember with all the pieces.
I could be wrong, but on the rear if they both use the same suspension type I think you can simply swap the complete axle assemblies. You probably don't want to run the 3/4-ton axle ratio anyway.
I know a lot more about '63 to '87 suspensions, but some of the slightly earlier stuff is very similar.
Where in WA are you?
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | What kind of wheels are they? If they're aftermarket custom wheels, they might be available in the 8 lug pattern.
Bill Burmeister | | | | | Joined: Jan 2009 Posts: 175 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 175 | To Oldsub I am in Bremerton Wa.
To Longbox55 The wheels are vintage aluminum slots that are on one of the trucks.
Thank you for all you guys information again and again | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Todjob, I live on Bainbridge Island and work in Poulsbo. I've been in Bremerton twice since I last posted in this thread. Maybe sometime I can drop by and look at your project?
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Apr 2009 Posts: 1 New Guy | | New Guy Joined: Apr 2009 Posts: 1 | Hi there. First time guy here and I got a question. I have a 1951 3100. We want to get it on the road this spring and want to change the 6 lug front hubs to a 5 lug hub. Does anyone know what hub will work? | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Welcome to the Bolt. There are several ways to go here. New axles, drilling out the hubs, changing rears and rear suspension + other stuff. Someone that has done this will drop by soon.
~Jim
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | There's 2 ways to do it. 1, get an aftermarket disk brake conversion, or 2, swap to '49-'54 Passenger car hubs and drums. Personally, I would do the first one. The rear axle would have to be swapped as well to keep it matched, but that makes for a good time to go to open driveline and an overdrive trans.
Bill Burmeister | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | ole boy, Just find a 53-54 Chevy passenger car and bolt the hubs & drums right on to your truck, no sweat. Not as easy for the rear, you'll need a complete rear end. I'd go a step better though and purchase the kit to swap on 5 lug discs, mucho better than drums. | | |
