Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
0 members (), 62 guests, and 2 robots.
Topics128,009
Posts1,055,293
Members48,419
#53930 12/24/2005 6:04 PM
I installed an overdrive transmission in my 62 1/2 ton truck last year-worked fine for a while but now jumps out of third gear going up a slight hill while in OD. Adjusted shifting arms, tried heavier grear lube (140 wt), all to no avail. Now just attach a bunji cord ! Any suggestions? All gears are quiet and mileage is over 20 mpg with my 235 six so would like to salvage the trans without having to pull it. This a three on a tree setup with a switch used to engage OD. Merry Christmas from Texas!
Green Machine
You'll need to replace the gear, baulk ring and syncro-sleeve to fix it properly. Maybe even the shift fork. Probably should do the bearings too while it's out and apart,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
Riding in the Passing Lane
You can pull the cover & check the shift fork & detent spring.
1972 Chevy c10 Cheyenne Super
Thanks for the replies! I am trying to keep from pulling the trans again. Wrenchbender please expand on your suggestion. Assume that I can pull the cover with the trans in truck. What do I look for? Also if I have another cover from a trans can't I just swap them out? The trans in truck is a Munsie and I have a cover from a Saganaw-will they interchange? Thanks for any help or ideas.
Green Machine
Junior Member
Junior Member
I have a 62 1/2 ton truck as well and am planning a tranny swap to a 3spd OD from a 59 Bel Air. Unfortunately I don't have any of the kick down stuff to engage the electrical solenoid. I can fab something if I knew what it was. What kind of setup kicks it into OD? I've thought about some vacuum switches from an AC unit. Thanks.
Priorities make dreams happen.
Stephan - the kickdown sw [on the carb] is actually to take it OUT of overdrive when you boot it - all you need is a manual switch to engage the OD when you want it, disengage when you don't - best to have an indicator light to show when it's on so you don't forget
for a non-original electrical setup, there\'s some wiring info here
