1 members (Hotrod Lincoln), 49 guests, and 6 robots.
Topics128,021
Posts1,055,355
Members48,420
#537312 05/13/2009 3:09 PM
Anybody know of a good source for vintage style tinted windows?
I am looking for the flat safety glass in a green hue. Today I only see the smoke, or charcoal style available. I also remember an orange tint on the old hot rods.
How do you measure the shade/darkness? What shade is acceptable for side and rear windows, as to the windshield?
Any leads appreciated.
Dale
46Canopy #537320 05/13/2009 4:02 PM
Glass shop.Check your state laws on tint or inspection station.I have the green hue in my 51.everything except the corner windows.
dan-pa
dan-pa #537332 05/13/2009 4:36 PM
Dale, as for what shade is acceptable I would recommend you stopping at a place that puts on tint film. They have a scale or pieces of glass, or film, to show you what is legal and what is not.
I just bought new "smoke" glass for my panel here locally. Since the rear doors is curved I took them to a film tinting place and picked out the tint I liked best....which happened to be just a bit darker than my side glasses....but they on the rear and will not be noticed much, if at all.
To get something like orange I would think you will have to have the glasses film tinted ....just my guess, unless special order from a glass company.
Of course, why did I not think of the glass or tint shop?
I am curious if anyone had luck with the vintage type of tinted glass that is laminated. Old school. Is there a special name to it? Luckily, I have all flat glass and when I redo the windows, I want just a faint trace in the windshield, and just a little more darker on the sides and back. Not looking for modern limo type.
Dale
46Canopy #537388 05/13/2009 7:53 PM
46,
I used this on my 4t6. It was purchased at the local glass shop. Soft green tint was the name about 60 beans each. I had all my glass cut there. Have fun and good luck
Dan
Chev4t6 #537419 05/13/2009 10:43 PM
Dale...Any good glass shop should be able to supply flat glass in a green tint,in either tempered or laminated.
Window tint film is fine but has it's limitations.(It's more prone to scratch and fade over time)
I'm lucky,I simply bought a sheet of green laminated glass and cut my own windshields.(This is my job)
The side (door) glasses I had made in 5mm tempered green glass,after I made templates.(This is more suited for doors etc.)
It can withstand more abuse i.e door slamming!
I'd post some pics but I haven't fitted them yet!
I hope this helps
Good luck
Jock thumbs_up
More pix on Flickr.
i lucked out .i pulled a freebie 350 out of a van we were scrapping at work.good motor mine fot the takin.put an ad in the free trader to sell it for parts money for the 49.a guys calls on it.says hes wanting to put it in a van for his business.says he owns a glass shop,weelllll.long one short i get all new greylight glass he even installed the glass in the side window frames, he gets his motor and it only cost me about 2 1/2 hrs labor..................dave
1949 Chevrolet 3100
"When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
Thank you all for info.
Dan, your windows look fantastic! Just what I am looking for.
Jock, so for the windshield I should ask for (soft) green laminated, and for the sides and rear, tempered (soft) green? As for the thickness, I am unable to measure the ones in the truck right now, as I am home. But you mentioned 5mm? Is that standard? Is auto glass measured in SAE, metric, or both?
I will insure the glass shop know it is for a 1946 Chevrolet truck, and use original glass for the templates. Great info.
Dale
46Canopy #537564 05/14/2009 5:58 AM
No tempered glass.It's a NO NO.Safty plate only .Can't cut tempered glass.Bump a edge an you have 10,000 pieces.The side &vent windows,rear &windsheld will cost around $280. Then you'll need new rubber for the glass & channel stripping for the doors.You don't want too crack those new windows.Good luck.A glass shop can cut all the windows for you. Saftey plate glass laminated.Canopy check my truck in the gallery 1951 dan kalenak
dan-pa
dan-pa #538123 05/15/2009 8:50 PM
dan-pa, If you read my post you will see I had my tempered glass 'made' to my templates. I did not say I cut them,
It starts life as standard single layer plate and is then 'toughened' in a heating process.
Why is tempered glass a NO NO?
Several million vehicles can't be wrong.
Manufacturers have been using it for decades now.
The reason it was used was,if in an accident you were (God forbid) incapacitated and the Rescue Services were unable to open the door due to damage,the window could be shattered into 'relatively' harmless (small) pieces to administer first aid quickly.
Try that with laminated side glass....
My front windshields are 6.4mm laminated glass (sorry 'bout the Euro metric talk!)
6.4mm Laminated glass on forward facing windshields is a Legal requirement over here......
Dale...the 5mm tempered glass was tight in my 50s frames, but I didn't use glass setting tape but instead a small section 'U' shaped rubber seal that I found at work and were hammered into the frames with glass cleaner as lube and a rubber mallet.
Again...try that with laminated.
O.K so it's not original,but neither is my engine,supension and so on....I think it looks good and I'm happy with it.
Whether you use tempered or laminated side glass is your choice.Either is alright.
Tempered was my preference for the reasons I have already stated.
Incidentally a 4mm (1/4" approx.)tempered door glass can easily support my weight and I'm 6'4" and 200lbs+ !
More pix on Flickr.
laminated safety glass is for windshields and cut to fit replacement side glass - tempered safety glass is used in all vehicle OEM flat/side glass as Jock sez .... plate glass of any type is architectural glass, used in buildings
laminated glass is used for windshields cuz when broken it stays in one piece, no sharp shards - tempered is used for the flat glass cuz cheaper and it shatters into fingernail size pieces when broken, no sharp shards, protecting the occupants [not helping the rescue boys] .... the 'fragile edge' of tempered glass is why GM used metal frames on the side glass for a time - but you won't find the average auto glass shop in N America to temper glass on demand, if they can't buy the piece factory made for the application
Flxible #538214 05/16/2009 2:46 AM
Jock, 6.4mm is 1/4", 5mm is .2" Not metric talk, just NASA talk....wait, they (messed) up the mars rover didnt they?
Either way, windshields are laminated to keep the rocks from hitting you in the head, the rest is tempered like Jock stated to pull ones back side from a wreck.
Flxible #538283 05/16/2009 7:33 AM
Originally Posted by red58
protecting the occupants [not helping the rescue boys] Bill
I agree Bill,but it works both ways.
Some of the worst cuts I've had has been from de-laminating glass. big_eek
One car a (F*rd Escort imported from the U.S.) was so bad it was like scimitar swords breaking away as I tried to remove the windshield!
(It must have come from a really hot State!)
Laminated glass is great,as long as it's in good condition.
Another point is,Tempered glass(toughened as we call it here) doesn't discolour and go brittle over time,unlike the yellow glass that was in my truck when I got it. grin
Sorry Scott,I was schooled entirely in Metric. I'm OK with feet and inches,but when you get down to fractional measurements,I'm stuffed! dang
More pix on Flickr.
Good safety info on glass. Looks like I will go laminated, as I will not be having the sides and back "made", but it sure makes sence. As for metric, sorry Jockbolter, I just noticed you are in Scotland.
Dale
