1 members (Cosmo),
86
0
Mod | | | Forums66 Topics128,049 Posts1,055,680 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2008 Posts: 138 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2008 Posts: 138 | Hi guys. I have a 47 1.5 ton that is a long term project. It's getting a set of bread truck axles, and I plan to make an air ride system for the back, and maybe the front too. My question is this, would I be better off welding the brackets for the air ride system to the frame, or bolting them? The truck will be getting an assembled vehicle title when it's done, so it will be inspected anyway...
Just wondered what you all think on this.
-Matt
| | | | | Joined: Mar 2005 Posts: 684 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 684 | | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy deerfanatic, welding anything to the frame, let alone suspension components, is an official no no, and would never pass inspection in my jurisdiction. You could bolt, rivet, or "Huckbolt" your suspension components to your frame, hope that helps. | | | | | Joined: Jan 2008 Posts: 227 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 227 | Welding.......  Drill holes and use bolts, fine thread with Nylock nuts. Keeps the Authorities much happier  | | | | | Joined: Aug 2007 Posts: 24 New Guy | | New Guy Joined: Aug 2007 Posts: 24 | I was helping a friend of mine on his truck a 53 1 ton, he welded some stuff on his frame. and the frame warp because of it. if you have to weld try a mig less heat and just for small jobs ie to tact | | | | | Joined: May 2009 Posts: 117 Shop Shark | | Shop Shark Joined: May 2009 Posts: 117 | no welding !! and as far as drilling the frame, if i were you i would try to keep it cool while i was drilling. | | | | | Joined: Aug 2008 Posts: 138 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2008 Posts: 138 | Very Cool. I was under the impression that welding was ok of it was going to be inspected afterwards.... Drill and bolt it is then! Thanks guys!
-Matt
