| | | Forums66 Topics128,162 Posts1,056,932 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#53556 12/15/2005 4:34 AM | Joined: Oct 2005 Posts: 28 Member | | Member Joined: Oct 2005 Posts: 28 | I have a 48 3/4 ton and I have put a 52 1/2 front axle under it. I was given a 1/2 ton 64 rear end with 3:73 gears and plan on putting it under the truck. I guess I would kind of end up with a heavy half. My intent is to build a driver but wish to get away from the old huck brakes and have a higher gear rearend. Has anyone tried this or does anyone forsee any problems? Thanks in advance for any input, OZ. | | |
#53557 12/15/2005 7:36 AM | Joined: Mar 2002 Posts: 990 Member | | Member Joined: Mar 2002 Posts: 990 | Well the first issue would be converting to an open drive line. There is no torque tube on the 64 rear end. | | |
#53558 12/16/2005 7:22 AM | Joined: Feb 2003 Posts: 452 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 452 | No worries on the driveline, as you probably know already. 3/4 tons are open from the pillow bearing back, so the only problem may be getting a u-joint to connect the old shaft to the new rear. Are your drums still in good shape? Good Huck drums are getting hard to find!
Current fleet (subject to change w/o notice) \'49 GMC 3/4-Ton , 60 Austin Healey Frog-eye Sprite (some assembly required), 2011 Dodge Avenger, 2015 Jeep Cherokee. No, they don't all run. My other ride is a (B737)no, (B767)no, A320.... Update... was Embraer E190, now Boeing B787. Knowledge is a wonderful thing, but ignorance means you don't know you can't do something.
#53559 12/16/2005 1:51 PM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | The 1/2 Ton front brakes can be converted to the 53 style and then you can buy new drums, if you care to do so. There are threads on this subject. | | |
#53560 12/16/2005 10:39 PM | Joined: Apr 2005 Posts: 345 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 345 | I have a '54 3/4 ton. For that year, my understanding is that the axel is narrower for the 1/2 ton than for the 3/4 ton, though I have never verified this for myself. As you probably know, the wheels go from 8 lug to 6 lug. | | |
#53561 12/17/2005 6:44 AM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Originally posted by ozscott: I have a 48 3/4 ton and I have put a 52 1/2 front axle under it. I don't have anything meaningful to add regarding the rear-end swap, but I'm curious how straight-forward the front swap was. Was it as easy as removing the 3/4-ton axle and bolting in the 1/2-ton?
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
#53562 12/21/2005 10:10 PM | Joined: Oct 2004 Posts: 348 Shop Shark | | Shop Shark Joined: Oct 2004 Posts: 348 | email me i converted two ad trucks including making the frame shorter [email protected] | | |
