6 members (55shaker, RdsLessTaken, Gdads51, Stewart2, Steelonsteel, Otto Skorzeny), 104 guests, and 3 robots.
Topics128,165
Posts1,057,010
Members48,458
#53556 12/15/2005 4:34 AM
I have a 48 3/4 ton and I have put a 52 1/2 front axle under it. I was given a 1/2 ton 64 rear end with 3:73 gears and plan on putting it under the truck. I guess I would kind of end up with a heavy half. My intent is to build a driver but wish to get away from the old huck brakes and have a higher gear rearend. Has anyone tried this or does anyone forsee any problems? Thanks in advance for any input, OZ.
Well the first issue would be converting to an open drive line. There is no torque tube on the 64 rear end.
No worries on the driveline, as you probably know already. 3/4 tons are open from the pillow bearing back, so the only problem may be getting a u-joint to connect the old shaft to the new rear. Are your drums still in good shape? Good Huck drums are getting hard to find!
The 1/2 Ton front brakes can be converted to the 53 style and then you can buy new drums, if you care to do so. There are threads on this subject.
1951 1 Ton Completed
I have a '54 3/4 ton. For that year, my understanding is that the axel is narrower for the 1/2 ton than for the 3/4 ton, though I have never verified this for myself. As you probably know, the wheels go from 8 lug to 6 lug.
Quote
I don't have anything meaningful to add regarding the rear-end swap, but I'm curious how straight-forward the front swap was. Was it as easy as removing the 3/4-ton axle and bolting in the 1/2-ton?
email me i converted two ad trucks including making the frame shorter [email protected]
1949 SUBURBAN
