12 members (Hotrod Lincoln, TUTS 59, Gdads51, KEVINSKI, Dusty53, Lonnie, klhansen, Geo55, Gray_Ghost, Otto Skorzeny, 2 invisible),
149
Mod | | | Forums66 Topics128,165 Posts1,056,992 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 14 New Guy | | New Guy Joined: Feb 2008 Posts: 14 | Hi everyone, just need a little advice again. I have a 1955 GMC truck with a bad gmc 248 inline 6 engine in it. The truck has a 3 speed column shift transmission in it. Can I pull the gmc 248 inline 6 and install in its place a rebuilt 250 chevy inline 6 engine without having problems getting the new engine to link right up correctly to the existing transmission in my truck? The transmission in my truck is stock... I know ill have to change motor mounts, because the chevy 250 has mounts on either side, whereas my gmc engine is mounted from the front, but will i have no problems grafting the chevy 250 engine right onto my stock 3 speed transmission? Please reply only if your sure you know... Thanks a bunch for the help! | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | You will need to use a v8 or 6 cylinder bellhousing from about 1962-1967. The earlier bellhousings will be setup for a hydraulic clutch. This should be a fairly simple swap. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy GMCUSTOM, actually you could use a bellhousing from a 55.2 - 59 V8, or a 63 - 67 V8 or 6 cylinder, as bigbadswingdaddy said, the 1960 - 62 were hydraulic clutch equipped, and there throwout arm comes out the right hand side, hope that helps. | | |
