6 members (Bill Hanlon, Cletus1950, Rustnut, Bucker, 52Carl, frogfarmer), 81 guests, and 2 robots.
Topics128,178
Posts1,057,063
Members48,460
Hi everyone, just need a little advice again. I have a 1955 GMC truck with a bad gmc 248 inline 6 engine in it. The truck has a 3 speed column shift transmission in it. Can I pull the gmc 248 inline 6 and install in its place a rebuilt 250 chevy inline 6 engine without having problems getting the new engine to link right up correctly to the existing transmission in my truck? The transmission in my truck is stock...
I know ill have to change motor mounts, because the chevy 250 has mounts on either side, whereas my gmc engine is mounted from the front, but will i have no problems grafting the chevy 250 engine right onto my stock 3 speed transmission? Please reply only if your sure you know... Thanks a bunch for the help!
You will need to use a v8 or 6 cylinder bellhousing from about 1962-1967. The earlier bellhousings will be setup for a hydraulic clutch. This should be a fairly simple swap.
3B Offline
Hy GMCUSTOM, actually you could use a bellhousing from a 55.2 - 59 V8, or a 63 - 67 V8 or 6 cylinder, as bigbadswingdaddy said, the 1960 - 62 were hydraulic clutch equipped, and there throwout arm comes out the right hand side, hope that helps.
