| | | Forums66 Topics128,021 Posts1,055,348 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 64 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2008 Posts: 64 | I am getting ready to blast my frame and was considering using Eatwoods chassis paint kit.I was wondering if anyone has used that kit and what kind of luck they had with it.I would like to powder coat it but am on a budget and if I could save that money and use somewhere else on the truck that would be good,if not I will suck it up and have it powder coated.Thanks for any advice you can give me on this. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | There is tons of post about paint vs powder coating vs POR15 and Rust Encapsulator and the list goes on. Personally I have painted the chassis on my 37 and I used Por15 on the 52 Panel chassis. I have NOT used any of the Eastwood chassis products but I would say I am very pleased with the POR15. Its tough as nails and gives good coverage. (it is not UV resistance but hey, its on a chassis) Do a search and gets tons of reading material but in the end its up to you and what works best in your situation. | | | | | Joined: Jul 2003 Posts: 586 Shop Shark | | Shop Shark Joined: Jul 2003 Posts: 586 | I have used Eastwood products and have been happy with them for the most part. I would use their Extreme Chassis products over the original. Its a lot heavier and covers better. Cecil..... | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | Longhorn, I used the Eastwood Extreme chassis black on my frame. My only complaint with it was that after a good cure of 2 months a leaky M.C. dripped overnight onto the frame and a-arm on the drivers side, it stripped the Eastwood down to the bare metal in NO TIME! I used POR15 on the underside of my hood and a few other places it seems to be a LOT harder than the Eastwood product. If I had to do over I would go with the POR15 for my frame and other OUT OF THE SUN places. Just my review of the product. Tim | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | I've used POR-15 but have had no experience with the Eastwood product,so I suppose my opinion is biased. I DO agree with Tim though,the POR-15 is as hard as nails and as long as you can deal with the UV sensitivity,it is a good product. I cleaned off some overspray on my POR with neat paint thinner and it never even marked the POR. I also took a bit of 40grit sandpaper to a small dried spill on my workbench,just to see what happened and it hardly touched it! My 2cents. 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Nov 2008 Posts: 64 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2008 Posts: 64 | Sounds like the POR-15 is the way to go.Did you brush it on or spray it on? Thanks | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Longhorn....I got good results with a brush,it flows well, covers easily and dries to a really nice gloss. I got loads done with a pint I initially bought to try. If you do decide to spray make sure you have the best breathing equipment. Oh..and read the instructions well about usage,storage after opening and definately wear gloves!!  1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Dec 2006 Posts: 443 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 443 | THIS IS POR 15 brushed onto my fender apron.If you click on the photo it will enlarge it and you can see it looks like it was sprayed on. POR 15 flows out very well so brushing it on looks fine and is safer on the lungs.(spraying it without proper respirator can mess you up bad or kill you.) 1957 Chevrolet 1/2-ton Stepside LB in the Gallery My Photobucket shots The person who has nothing for which he is willing to fight, nothing which is more important than his own personal safety, is a miserable creature and has no chance of being free unless made and kept so by the exertions of better men than himself." - John Stuart Mill (1806 - 1873) | | | | | Joined: Mar 2009 Posts: 91 New Guy | | New Guy Joined: Mar 2009 Posts: 91 | We painted POR-15 on my son's frame. It looked great for about a year, but it still chalked even though it's not in the direct light. | | | | | Joined: Jul 2007 Posts: 28 'Bolter | | 'Bolter Joined: Jul 2007 Posts: 28 | I used POR 15 on a pontoon trailer i built. It has a matched top coat on it to protect it from UV. the steps and other vulnerable areas do not have any wear spots, chips, scratches, etc. after 4 years of hard service.
I plan on using POR 15 on the chassis of my 41 pickup very soon. I am not familiar with the other products mentioned, but I am very please with this stuff. I tried hammering it off of a piece of scrap metal and couldn't. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | It depends on what kind of truck you want to have when you are finished. If it will be a show truck, powdercoat it; if it will be a "real pretty" truck, prime and epoxy it. You don't have to worry about rust holes in the chassis. The only rust will be surface rust. If you plan on driving it much it won't be long before all that "nice" look will be gone.
~Jim
| | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | I like the Zero Rust paint. I only use it over the POR-15 because I can get it at my local store, KMS in Vancouver area. IT brushes on really nice, but I have also used their spray. They also make a clear coat for protecting the paint. I like the look as it is not super glossy. Comes in primer gray too. There is a review on this site. http://www.stovebolt.com/techtips/rust/zerorust/zerorust.htm A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | | | |
