1 members (Naturalthud),
110
Mod | | | Forums66 Topics128,135 Posts1,056,423 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2006 Posts: 100 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 100 | There is a hole in the center at the rear of the bed sill. i no this is for the J hook for the spare tire on 3/4 tons and may be bigger. Was this hole there on 1/2 tons and not used or should this not be there at all. | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Yes there is a hole on half ton trucks in the same place. The underbed carrier was changed after about 1950 or 1951 and the hole no longer used in that location but might still be there on later years. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Panels may be different.... my 52 half ton panel utilizes two cross pieces that the stuff hangs from. | | |
