3 members (Southerntruck, JW51, Lostbuthaulinass), 120 guests, and 0 robots.
Topics128,114
Posts1,056,285
Members48,439
Junior Member
Junior Member
I own an all original unrestored 1953 3800 with 216 motor. I know it has the original engine and original harmonic pulley on the front of it. Question is can this 52 years old balancer be functioning properly? I would think the rubber ring would deteriorate. How long can these last. Am I risking a crankshaft failure?
Getting oil on it will kill them faster than anything. How does it look? Is it weather checked or oil soaked? Is the outer ring still in line with the inner? Can you put some force against it with a prybar and get excessive movement? I've only heard of replacing them when they fail or while one is already off. May also open a can of worms trying to replace it as preventative maintanence too.
Just somethings to think about,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
I'm sure they do fail, but I personally have never heard of one doing so. I'm not a professional mechanic, but I have been a car nut all my life. If it looks ok, I would take the "if it's not broke, don't fix it route" Allen
Yes, they can and will fail. The lifespan of rubber is short, and depends on the formulation and use, and oil will shorten that time. Problem is replacing it. I have found two outits that will rebuild the damper, and they're far from cheap. Most of us continue running the original. My friend is using a fluid filled damper for a small block on his 261, he dad to modify the damper come up with a pulley setup.
Fred
52 3600
69 C-10
The dampers on 216-261 and some GMC's is different than the typical V-8 damper.It's like a sandwich,plates with rubber in between,it can't slip and spin due to the construction of thru rivits.
Fred,a third place,Dale's Damper rebuilding does a better job for less money,about 100 bucks for any damper,search the web for his address.Dale says he uses a rubber with the same hardness as the original to keep the damper tuning proper.The weight of the internia ring and the rubber is tuned for a certain rpm,whatever that may be.
I was gonna use a Fluidamper on my recent 302 GMC build,but I heard of crankshaft and bearing failures directly related to the use of this style damper when used on GMC 6's.The 302 damper ,at least most of them,is similar to a V-8 type,the outer ring on mine slipped and when I removed it,the outer ring actually fell off!!!
