8 members (wilbur53, mason86, ndkid275, Otto Skorzeny, 32Fordpuchoptop, klhansen, Hotrod Lincoln, 1 invisible),
114
0
Mod | | | Forums66 Topics128,050 Posts1,055,676 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2006 Posts: 584 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 584 | Are the bell housings and trannys in commercial 41-46 big trucks the same or compatible with the military versions? | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | I want to say yes for Chevrolet, but GMC may have had some diesel engines available in those years and I seem to recall some may have had automatic transmissions. 3B should know this for sure. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Tomcoe, as rustednuts said, your question is too broad. Are you asking about just Chevrolets, or G.M.C.s as well? | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Per my OLD parts book all trucks are the same but does not list all the cab over models. If you can get the casting numbers I could look them up though.
Jim | | | | | Joined: Jul 2006 Posts: 584 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 584 | Hi Guys,
Thanks for the info. Chevy to Chevy. I was going to use a COE as a doner tho so I wonder what could possibly be different? I'll see if I can get castings. I can on my COE, but maybe not my friends that needs replaced for some time. Thanks again | | |
