0 members (),
80
Mod | | | Forums66 Topics128,266 Posts1,058,385 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2008 Posts: 34 New Guy | | New Guy Joined: May 2008 Posts: 34 | I put a new fuel tank in my 53 about a year and a half ago. I have developed a leak around the brass tube coming out of the bottom. (where the tube runs through the tank) Any suggestions on how to fix,(jb weld)?? or has anyone else had a problem with a newer tank like this one? http://community.webshots.com/user/53jimmy
The best things in life are FREE!
| | | | | Joined: Oct 2006 Posts: 843 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 843 | look for a product called"Seal-All" it comes in a tube,like model cement.I've had success with it | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | On my original tank in the COE, the fittings were soldered. I broke one loose and ended up bringing it to a friend of mine who cleaned it right up and resoldered it perfectly. Hasnt leaked since.
Ive had JB weld soften and leak when exposed to gasoline for a marked amount of time. That doesnt mean it wont work, just that it may be a short term fix. | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | Don't mess around with gas tank leaks! Get the thing repaired properly. | | | | | Joined: Jul 2005 Posts: 581 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 581 | I used jb weld on my tractor to stop a leak at the shut off valve. No leaks in 2 years. I did buy a new valve but it was chinese junk, leaked worse, and wasn't machined. Eventually I'll do it right, but I just watch it for now. | | | | | Joined: May 2008 Posts: 34 New Guy | | New Guy Joined: May 2008 Posts: 34 | Thanks for all the tips. I figures I might as well have it done right the first time. I dropped it off yesterday to have it soddered up. Thanks again for all the tips http://www.webshots.com/user/53jimmy
