| | | Forums66 Topics128,079 Posts1,056,286 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 16 New Guy | | New Guy Joined: Jan 2009 Posts: 16 | I want to know if you used a frame swap kit or just winged it. If you did use a swap kit was it worth it? | | | | | Joined: Jun 2007 Posts: 53 Shop Shark | | Shop Shark Joined: Jun 2007 Posts: 53 | I am in the process of putting a 58 fleet on a 91 s-10 frame and no kit, I built everything that I needed from scratch, and sold the motor mounts I had purchased from Jtr. I needed the 350 higher and back farther than they would allow, moved the rear end back 6 1/2 inches from info I dug up out of the H.A.M.B. form at the jalopyjournal.com site Good Luck with your swap
MikeB | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | I have seen the swap done with a kit from AD Engineering. The fellow who did it said it worked well saving a lot of fabricating on his part. | | | | | Joined: Mar 2009 Posts: 11 Apprentice | | Apprentice Joined: Mar 2009 Posts: 11 | I did it without a kit. I mounted the cab using home made cab mounts I built from 4x4 square tube at a total cost of about $6. Mounted a modified original rad support on a couple angle brackets to the frame, and I'll let you know what I do with the bed when I get to that part. I didn't find anything too difficult to accomplish, and it was all cheap which was key for me. If you want to know any moredetails of how I did it send me an email, I'll tryto answer your questions. | | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | Do a search in the Hi Po shop forum. There are lots of threads over there about the swap.
-W
| | | | | Joined: Nov 1995 Posts: 5,723 24601 | | 24601 Joined: Nov 1995 Posts: 5,723 | Be sure you check out a fellow Bolter's site for the S-10 Swap Kit -- Mongo's Garage KCMongo is one of our moderators and a good friend. He's in the HiPo shop and can give you lots of advice, even if you don't buy a kit from him. Good luck! John
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: May 2007 Posts: 275 Shop Shark | | Shop Shark Joined: May 2007 Posts: 275 | I did it with a kit that I obtained from EZ Swap and it went like a dream. A very well made kit. I wouldn't do it again without it. here is the link: EZ Swap
No better smell than that of fresh paint. I've been building and painting cars/trucks for 47 years. Not gonna stop now. http://www.coxcustomcars.com/ | | | | | Joined: Jun 2008 Posts: 13 New Guy | | New Guy Joined: Jun 2008 Posts: 13 | Here's a link to my build thread. I put a 48 5 window on an S10 chassis with no kit, just a little elbow grease. http://www.killbillet.com/showthread.php?t=16296
| | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 |
