4 members (Otto Skorzeny, Phak1, Gdads51, Ponchogl), 131 guests, and 3 robots.
Topics128,272
Posts1,058,316
Members48,485
#532499 04/27/2009 2:10 AM
wheels for disc brake conversion. will late model Colorado 16 in. wheels fit over a front wheel disc brake conversion on a 50 chevy 3100.? What wheels will fit.? thanks
#532509 04/27/2009 2:25 AM
Short answer, no. While the wheel will physically clear the brakes, the deep backspacing will make it rub the tie rods. I would suggest a '73-'87 soloid axle 4x4 wheel, like the Blazer Rallye Wheels. Other wheels for that fitment should work fine, too. I am making that suggestion based on you keeping the 6 lug bolt pattern.
Bill Burmeister
LONGBOX55 #532852 04/28/2009 2:43 AM
rfortner: I have a friend who has a set of Colorado wheels on his 50 but if my memory is correct he changed the tie end rods and now has a clearance of about 3/8 inch. Also I have heard of folks using spacers but most don't like that idea.
There are some options out there if you look around a bit.
Achipmunk #533013 04/28/2009 3:38 PM
late 70 - early 80 jeep
toyota 6 and nissan 6 work
Jim & Caroline
