| | | Forums66 Topics128,034 Posts1,055,544 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2004 Posts: 22 New Guy | | New Guy Joined: Aug 2004 Posts: 22 | wheels for disc brake conversion. will late model Colorado 16 in. wheels fit over a front wheel disc brake conversion on a 50 chevy 3100.? What wheels will fit.? thanks | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Short answer, no. While the wheel will physically clear the brakes, the deep backspacing will make it rub the tie rods. I would suggest a '73-'87 soloid axle 4x4 wheel, like the Blazer Rallye Wheels. Other wheels for that fitment should work fine, too. I am making that suggestion based on you keeping the 6 lug bolt pattern.
Bill Burmeister | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | rfortner: I have a friend who has a set of Colorado wheels on his 50 but if my memory is correct he changed the tie end rods and now has a clearance of about 3/8 inch. Also I have heard of folks using spacers but most don't like that idea. There are some options out there if you look around a bit.
| | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | late 70 - early 80 jeep toyota 6 and nissan 6 work
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
