| | | Forums66 Topics128,185 Posts1,057,294 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#53211 12/07/2005 5:51 AM | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | I'm planning on begining the installation of my 55 car rear end under my 37 truck within the next few weeks. I'll be going from a closed driveline to an open driveline, finally! A friend tells me that I will have to reverse the rear springs in order to have the rear wheels centered in the fender opening. :confused: Can anyone verify this? If so, why? Thanks, Joe
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | |
#53212 12/07/2005 6:46 AM | Joined: Dec 2003 Posts: 975 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 975 | 22 years ago, I put a 57 Chev car rearend under my 41..the guys that were building piles of cars back then said it the perfect fit. I must admit..I never got the rear fenders put back on, but it looked pretty normal to me...I know the 37 and the 41 are a little different, but they must be pretty close too. | | |
#53213 12/07/2005 5:50 PM | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Joe, I'm sure this is not an issue with the 37 pickup or later pickups up to 46. The issue is the relationship of the axle to the centering bolt of the spring pack. The later trucks after 47 plus the passenger cars, had a 'pivot' that was behind this centering bolt. This made the later rear ends off center in the wheel well when swapped in. Your original 37 truck axle pivoted directly over the centering bolt so you shouldnt have a problem.
On the 57 car rear end, you probably will have to cut off the spring mounts and swap in a kit or make new, don't force the springs out to fit. I had to use lowering blocks with both axles I've used on my 46 as the original cast iron mount was taller. Have fun. | | |
#53214 12/07/2005 8:01 PM | | Anonymous Unregistered | | Anonymous Unregistered | Joe, I put an open driveline in my '37, but I used '55-'59 1/2 ton components. The wheels do sit a little forward in the rear fender openings. I've heard about reversing the springs also, but when I measured mine they sure seem to be symetric. I may be wrong, but I don't think reversing them will help. Mine measure the same from the center locating bolt to each end. If you find out any more about this or try it, be sure to let us know what the results are. | | |
#53215 12/08/2005 4:20 AM | Joined: Mar 2005 Posts: 49 Member | | Member Joined: Mar 2005 Posts: 49 | 6 cyl - Did you check you're measurements on that 55 rear? Seems like they are about 62" wide which will put your tire right at the fender. your 37 is probably about 58 - 60 wide. I put an S10 rear in my 39 which is about 59 wide. This gives you a little wiggle room if you put a larger tire on or if you go radial. Of course you can do things with offset rims but they can also change the look. | | |
#53216 12/08/2005 5:22 AM | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | gaffbro - I am currently running a 54 Chevrolet car rear axle under my truck now. It measures 61 1/4" wide and fits under the truck just fine. The 55 Chevrolet car rear end measures 59 3/4" wide, so I should be OK. If not, I'll have a 55 Chevrolet car rear axle for sale! Joe
#53217 12/08/2005 5:23 AM | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Joe, unless you have to use the 55rear end why not try something else?? I used a 78-80 Malibu under my 37 and it works great. I did put some lowering blocks under the rear but the centering holes matched up..... at least on my resurrected truck!!! | | |
#53218 12/08/2005 5:46 PM | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | You can fine tune the fore-aft placement on any rear end you use via the lowering block. If you don't want or need a lowering block, use a lets say 1" thick block, same width as springs and about 5-6" long. Get a used round head spring bolt and weld it to this 'block'so that just the head sticks out and is centered. On the flip side drill a row holes same size as round head, maybe 3/4" appart (These dimentions you can adjust as needed) first hole directly under the bolt. Then add holes away from center towards one end. Lowering blocks are inexpensive but can also be made very easily with rectangular tubing.
Now you have a method of adjusting the placement of the rear end via this little block. This item may be available through various hot rod/chassis vendors. | | |
#53219 12/08/2005 7:04 PM | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | some where I heard that it is best to use a truck rear-end vs a car, something about more strength, but that may or may not be true,the decatur meet is in Feb,,, better get started..Fred Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | |
#53220 12/09/2005 2:36 AM | Joined: Jun 2005 Posts: 49 Junior Member | | Junior Member Joined: Jun 2005 Posts: 49 | 6cyl.
Im planning on swapping my rear in my 38 3/4 ton
let me know how it all works out for you | | |
