2 members (Hotrod Lincoln, wilbur53), 154 guests, and 2 robots.
Topics128,162
Posts1,056,937
Members48,458
24601
24601
Can anyone tell me the correct plugs (and gaps) for a '65 305 V-6? The engine is in a 4000 series (ton and a half).
The engine is not running quite as smoothly as it should and has a little bit of a miss. I am going to pull the plugs to check the gaps, porcelain for chips & cracks, etc. But I have no idea what the gaps are supposed to be, actually ...
A quick recap -- The engine has new cap, rotor, points, condenser, coil, wires and plugs. Also, a freshly rebuild carb with a new mechanical fuel pump with a brand new electric back up (On the way to a show last year, the truck's mechanical pump failed and packed the crab full of diaphram bits, caused an engine fire and caused a lot of issues going home most of which have been corrected now except for this missing. A professional truck mechanic did the compression test, rebuilt the carb and double checked the timing and point gap. We have not yet pulled the plugs and double checked them.
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
Riding in the Passing Lane
I can get them tomorrow John if no one comes up with it between now & then. George
1972 Chevy c10 Cheyenne Super
here you go john i just dodged the rain drops out to the shop c44ns plugs and .035 gap
Just a thought - when was the last time you adjusted the valves?
David Colter
pics * 1954 wrecker * [color:#009900]1948 Chevy 1-Ton[/color]
Old Dog & George -- Thanks -- I hope nobody got too wet. Was that AC-Delco on the plugs?
David -- Good question. They've not been adjusted since I've owned the truck and may not have ever been adjusted since they were set on the assembly line. Remember -- the truck has 10,000 miles on it -- 2,000 since I've owned it. What should they be set at?
v/r
~ One of many.
Valves don't usually get too tight on their own, which would be the only way they would cause a miss. If they were too loose then they would be obvious, too much noise,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
I thought that a loose exhaust rocker could cause the engine to run rough, and it seemed like one thing not already done.
John, I have no idea what they would be set at - just talking shop and learning from the best.
David Colter
yea that was ac delco ,i didn't worry to much there wasn't any soap in it .
Here's a copy of a page out of my '72 GMC 4500-9500 owners manual.
http://image62.webshots.com/662/7/43/48/2348743480103559715JDkNRV_fs.jpg
if you need more let me know.
