1 members (delky),
130
Mod | | | Forums66 Topics128,062 Posts1,055,854 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 256 'Bolter | | 'Bolter Joined: Jan 2009 Posts: 256 | I haven't had a bolt I couldn't get out til now. The 6 bolts holding the front bumper brackets to the frame won't move. Its a 53 and I don't think they've ever come off. I tried PB Blaster, a propane torch, and wrenches with a breaker bar. Nothing will move the thing. Any tricks for getting this thing off short of cutting the head off the bolt??
| | | | | Joined: Feb 2009 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2009 Posts: 66 | I had the same thing on my '70 GMC. I tried but ended up bending or snapping all of them, but I would try this stuff called Liquid Wrench. It works pretty well.
"So this year, I am upgraging my policy of zero tolerance to one of SUB-zero tolerance, which is MORE than zero." -Principal Jindraike
| | | | | Joined: Apr 2009 Posts: 192 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 192 | try a few applications of rust remover (wink,clr)on a rag soaking on the bolt. Then WD-40 after all the visable rust and gunk is gone. If that doesn't work ? Work on one until you find a solution,good luck. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Impact gun. Or, save some trouble and go ahead and cut them off. Replacement bolts are easy to get.
Bill Burmeister | | | | | Joined: Feb 2009 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2009 Posts: 66 | Whatever you find that does work, let us all know how you did it so we can know too.
| | | | | Joined: Feb 2004 Posts: 29,774 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,774 | Kroil! www.kanolabs.comIf Kroil won't loosen the bolts, better get out a grinder or a nut splitter! Jerry
| | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | they aren't stuck you just haven't used a big enough hammer.
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | If you don't need to save them just wrench on them until they either unscrew or twist off. They are only 1/2" bolts right?
Otherwise PB Blaster and time, or if that's not enough persuasion some serious heat should do the trick.
Grigg | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Use a breaker bar and tighten them until they snap off. Then get new ones, Scott | | | | | Joined: Aug 2005 Posts: 28 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 28 | Propane does not give off the heat that an oxy acetylene torch does. Thats always worked for me. Worse comes to worse cut them off. | | | | | Joined: Jan 2009 Posts: 256 'Bolter | | 'Bolter Joined: Jan 2009 Posts: 256 | I cut the nuts off, I cut the heads off. The thing still won't budge. I got out a grade 8 bolt the same size and a sledge hammer and its still stuck in there. Who assembled these trucks?! | | | | | Joined: Mar 2005 Posts: 637 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 637 | | | | | | Joined: Aug 2005 Posts: 28 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 28 | In cutting it out you probably welded the thing in there. It sounds like Murphys Law to me. | | | | | Joined: Jan 2009 Posts: 256 'Bolter | | 'Bolter Joined: Jan 2009 Posts: 256 | I only cut one of the bolts, the others still wouldn't come out with the heads intact. I ended up slowly increasing the drill bit size til there wasn't much left than was able to pound the bolt out with a hammer. Only 5 more to go  | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | you didnt use a large enough hammer. Usually a 5# fist maul and lots of pent up anger is all it takes to punch a bolt out with a drift after taking a grinder to the head
| | | | | Joined: Jan 2009 Posts: 256 'Bolter | | 'Bolter Joined: Jan 2009 Posts: 256 | Well, I finally was able to get all 6 of the bolts out. I had to cut off the heads on all of them. I used a sledgehammer and a pole that came to a blunt point on the end to punch them out. By the end, plenty of pent up anger was showing its colors. I was making so much racket that a neighbor yelled over "You're not supposed to break it!"
| | | | | Joined: Apr 2006 Posts: 136 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 136 | Should'a told your neighbor to get off his butt, and help ya. Then he'd see how hard you were workin', and he would keep his mouth shut. Ha. | | | | | Joined: Apr 2006 Posts: 136 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 136 | By the way, I have to do the very same thing as you, because I tried to take one of my bumper bolts out the other day, and she wouldn't budge. Not lookin' forward to it, but I want my new bumper on. | | | | | Joined: Apr 2009 Posts: 192 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 192 | Your neighbor,he obviously drives a Lexus ? | | | | | Joined: Apr 2009 Posts: 60 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 60 | Heat nut red hot with oxy-acetylene AND ALLOW TO COOL, if this doesn't get it cut em off and get new ones | | |
