| | | Forums66 Topics128,211 Posts1,057,472 Members48,473 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2004 Posts: 52 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 52 | I have a 49 GMC with at 125-1/4 wheel base and I have a spare rear-end that came out of a truck with a 116" wheel base. I am guessing the torque tubes are of different lengths. If I need to use the spare rear end under my 49, can I take the torque tubes off and switch them? And on top of that, one is a Chevy and one is a GMC, wonder if that makes any difference? I have never had to take a torque tube off a rear-end before and have never ever seen the driveshaft out of the tube. [email protected] thanks.
Whether you think you can or can't, you're right.
Also--in 2004, I invented the spotting alert network in stovebolt after seeing so many trucks when driving around. So that means I am cool.
| | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | Your profile says the '49 is a 3/4 ton. Didnt they come with the open drive shaft rear end? | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | If it's a 3/4 it should have an open drive. Most driveshaft shops can fab a new one with the correct yokes and length.
~Jim
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | He may have a half and half driveshaft? half open half closed? | | | | | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | "He may have a half and half driveshaft? half open half closed?"
Yes, front side closed, back side open.
The only way to use that 1/2 ton torque tube rear would be to remove the third member and swap in a '55-'62 1/2 ton third member to get to open driveline. | | |
