| | | Forums66 Topics128,151 Posts1,057,000 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2006 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2006 Posts: 127 | I'm in the process of getting my cab sandblasted/primed, but in the meantime, I'm about to start cleaning everything, such as the horns, distributor, carburetor, oil bath, etc - Everything is gunky, really dirty and some rusty... what is the best thing to use? | | | | | Joined: Jul 2007 Posts: 461 Shop Shark | | Shop Shark Joined: Jul 2007 Posts: 461 | Carburetor cleaner for the carburetor, Stoddard solvent (parts cleaning solvent) for everything else. If you slash Stoddard solvent on your clothing, even a small amount that you might be temptee to ignore, change clothes and wash the area, or you will regret it. Stoddard solvent is a strong oil solvent, which if left on clothing where it will chaffe your skin, will cause what amounts to a chemical burn and a blister that becomes very large, very painful and slow to heal. Its a common mishap that only happens once to the same person. Trust me on that.
Harvester | | | | | Joined: Feb 2000 Posts: 90 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 90 | Wear Rubber gloves & googles while using solvents. It can (will) be absorbed into your body and cause internal organ faliure. Simple Green is good stuff for most "Gunky" stuff and Easy-off oven cleaner works for heavier caked on mess. Be careful, these things can burn. Harvester is correct. | | | | | Joined: May 2007 Posts: 41 Wrench Fetcher | | Wrench Fetcher Joined: May 2007 Posts: 41 | Hey Blake,
I have always used gasoline. Its just as nasty as any other chemical, works better in my opinion. and is only 2.29 for a gallon of the stuff currently, vs about 3.49 for a rattle can of of carb cleaner or brake parts cleaner. Just submerge and brusk away. I do also recommend using gloves, an apron, safety glasses, and doing everything in a well ventilated area.
Eli | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | Pressure wash the gunk first. I use 2750 psi. | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Purple Power Industrial Degreaser is what I use. It takes a longer soaking, but knocks down the grease with a bristle brush and is biodegradible.
Drew
| | | | | Joined: Aug 2008 Posts: 403 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 403 | Cleaning with gas is asking for trouble! Had a friend using it and it enigited with static electricty! Now everyone knows what happens with gas YOU CAN'T WASH IT OFF WITH WATER AND YOU GET A NASTY BURNS. Better to use the Purple Power Ind. Degresser its much safer. 62Blue Don
62Blue 62Chevy in progress You've never been lost until you've been lost at Mach3" Paul F Crichmore (Test Pilot)
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I prefer Super Clean over Purple Power, Super Clean seems to be a bit stronger. A quick warning using Purple Power, Super Clean, Simple Green, and similar products- If you soak any painted parts in them for more than maybe a 1/2 hour, it will take the paint off. Also, do NOT use it to soak nay kind of die cast parts. A short soak, scrub, and rinse will be fine, but leaving die cast parts in those kind of cleaners will result in a ruined part, as the dissolve the metal. If you mist soak a die cast part, use Simple Green, as it will only discolor the part, but won't do any major damage. It will remove any paint from it, though.
Bill Burmeister | | | | | Joined: Feb 2007 Posts: 435 'Bolter | | 'Bolter Joined: Feb 2007 Posts: 435 | Dawn dish soap works really well with a pressure washer after it's been soaking for a while. Cheap too. | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | Dawn is the only soap in my garage. | | |
