4 members (Gdads51, GRNHydra, Oswald, texczech), 79 guests, and 3 robots.
Topics128,060
Posts1,055,839
Members48,427
#528002 04/13/2009 8:51 PM
Last year I took the oil pan off of my 50 216 to do an internal inspection and replace the gaskets. I cleaned about 1/2" of deposited dirt and sludge out of the bottom. I cleaned and inspected as good as I could, repainted the outside and reinstalled with a new gasket. Almost immediately a pin hole shown up. I did what any self-respecting redneck might do - ran a sheet metal screw thru it. That almost stopped the leak. Later another pin hole. I made up a little JB Weld and covered the area where both holes are. First re-fill of oil (after replacement of pushrod cover and valve cover gaskets) and a 15 mile trip around the area and - you guessed it - another pin hole. Corrosion from old, dirty oil right? That old dirt was sealing the holes. Anybody else had this? Any remedy besides a replacement pan?
Professional Novice
Frank50 #528006 04/13/2009 8:59 PM
Corrosion from water in the old, dirty oil - maybe?
You could try to salvage the pan by taking it off, thoroughly cleaning the grease and paint (if any) off of it, and then coating the inside and outside with POR-15.
Professional Novice
Frank50 #528330 04/14/2009 2:07 PM
I would take the pan of and have a sheetmetal patch welded in.....or find a replacement pan. They can't be that hard to find.
Builder #537327 05/13/2009 4:25 PM
Well they say JB Weld can fix anything so I tried it. After a more thorough cleaning inside and out and inspection I dobbed some JB inside and outside on the most corroded spots and let it cure for a couple of days. Then 2-3 coats of enamel inside and out and after another 24 back on with the same gasket. Re-fill and drove about 40 miles and not a drop! smile It's been parked now for about 5 days and still no leaks!
Professional Novice
Frank50 #537356 05/13/2009 5:53 PM
There are lots of old engines around. I would look for a good used oil pan.
I see oil pans on ebay pretty often. No sense patching on a piece of Swiss cheese! A good welder can probably replace the entire bottom of the corroded area with a piece of NON-GALVANIZED sheet metal, about 16 or 18 gauge. Galvanized metal gives off toxic fumes when it's welded, and the zinc coating might flake off and score bearings.
brass...if you can braze that is, brass will stop that leak forever
1966 Chevy C/60 Wrecker
Story in the Gallery
Pictures on Flickr
It don't rust if you run it hard enough
If you run across a good pan, you might grab it, just in case.
Although the JB Weld will probably last from now on.
1949 Chevy 6400
1931 Chevy Firetruck
