1 members (Ponchogl), 182 guests, and 0 robots.
Topics128,101
Posts1,056,180
Members48,436
#515476 03/10/2009 5:12 PM
I'm looking for a flexible fuel hose from the tank to the solid line. I can get one mail-order but decided to try the FLAPS. They all shake their heads as if such a thing doesn't exist. The hose I want is exactly like my flexible brake lines but the next size up. Can you use brake line hose as a fuel/oil line? My truck uses a 5/16" fuel line. Anyone have perhaps a current NAPA# for this item? Thanks
Kyle
1941 G506
More
1946 3800
Pic
More
1946 3600
Pic
More
1924 Ford Model T Fordor
Ex Hall Monitor
Ex Hall Monitor
Just buy a length of 5/16" rubber fuel line & put barb fittings on the ends. I can't believe any FLAPS wouldn't carry what you need. I've got a short section on my 38 between the filter & fuel pump.
Tiny #515496 03/10/2009 6:04 PM
Ahh, good point. Probably much cheaper. Anyone use a drain petcock or shutoff at the tank?
Kyle
1941 G506
More
1946 3800
Pic
More
1946 3600
Pic
More
Definately use a petcock on the bottom of the tank. The last thing you want to do is have it drain out when your working on the fuel line, pump, etc.
Jeff
My 1953 Chevrolet
1947.1 Gallery
Ditto on it being a standard item at all parts houses. However, you need to be aware that the old time rubber fuel hose should be replaced with E10 rated hose that has a blue inner liner. The 10% (or less) alcohol will cause an unlined rubber fuel line to get soft, the clamps start to allow fuel to leak, and you've got the potential for bad things to happen.
Dave
Webshot "Tips and tricks" and "Shoebox" Photo Albums
EXPERIENCE is the best teacher...but it gives the test first...and the lesson afterwards.
"What this generation tolerates...the next will embrace"
Kyle,
Did you find a source for the flex fuel hose? Thanks to Nate's suggestion over at old-chevy-truck, I've been able to repair mine.
Nate posted:
"...if you look at your old leaky flex line , each end is held on by a crimped bit of sheet brass , you can carefully cut this and the old hose will slide off the fittings revealing standard hose barbs , any Hot Rod or boat shop should be able to have a new hose crimped on or just use new std. hose with regular hose clamps ...."
On mine the brass wasn't barbed and I though it was too short to just clamp a hose on and risk it sliding off, so I flanged them with a big phillips screwdriver AFTER heating them up with a propane torch. If you don't heat the brass it will split. A solid "tap" and some twisting of the screwdriver gave me a nice little flange. There was just enough room left for the clamps to fit ahead of the flanges for a secure fit that won't slide off.
Click here for a photo:
Flex fuel hose repair.
Tim
