1 members (baldeagle),
35
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2009 Posts: 100 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 100 | Gas vapors expell out of carb for 10 mins after i shut the truck off. This goes along with my other issue i guess. The engine continues to start and idle great, but it will not handel an acceleration from the throttle unless you increase the throttle very very slowly, and then it does want to regain idle for a couple of mins. Its an inline six 65 chevy. I just bought it and it ran perfect for the first 45 miles or so then with out any changes to the truck it just cut off after shutting it off for 30 mins to go into a store. The truck made it 30 feet and quit responding to the throttle and shut off. It happend without any pre warnings. It did not show any signs there was an issue, not even a noise difference or drive difference from when i turned it off to go to the store to strating back up to leave. Some people have mentioned maybe its a stuck valve, but it hard to believe it would be that with out some sign, at least a small one. It was running perfect. Thats what made me think maybe a carb or vacuum issue. Here is a list of my trouble shooting and the stuff i've done so far. Also, i have a glass fuel filter and i see that it stays full of clean fuel so i dont think its a clog or the fuel pump.
1. I put a new carburetor on it 2. 6 new spark plugs 3. new fuel filter 4. distributor looks good 5. distributor does not have a vacuum hose port 6. the carburetor has a vacant port next to the fuel/air mixture screw that makes a sucking sound when running, but there is no where to run a vacuum hose that i can tell. I have tried plugging the hole but it makes no difference in condition. 7. when the throttle is pushed at normal or fast speed it makes a giant air sucking noise and spits blacksmoke out the rear. 8. i pulled the valve cover off and the rockers look good.
please help
It's better to have it and not need it, then it is to need it and not have it. "Woodrow F. Call"
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy mswilkes65Chevy, firstly plug that leaking port on the carb. How many miles on this engine? Check the dwell and then check the timing. As far as I know your distributer should have a vacuum advance on it. | | | | | Joined: Mar 2009 Posts: 100 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 100 | i have plugged the port, the engine has about 5000 miles on it, the timing is good, and i dont know what the dwell is. Where would the vacuum advance be, i cant find it or i dont know what i am looking for. thanks for the help
| | | | | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | the vacumn advance goes down from carb to the dist. it should be a small hose smaller than fuel line. this is a rochester b right on a 65 chevy? if you have a hei dist you woun't have to worry about the dwell setting but you will if you still have points. have you checked how much vacumn you are pulling and set the timing with the vacumn gauge? might give it a try, might find out if it timing or vac leak or what. you can't always trust a new carb too. good luck. hr | | | | | Joined: Mar 2009 Posts: 100 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 100 | its a holley 1 barrell carb, this engine is not the orginal inline six. This one cam out of a boat new, it is a gm motor.
| | | | | Joined: Mar 2009 Posts: 100 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 100 | where is this vacuum advance at, cause i cannot find one anywhere on the distributor itself
| | | | | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | the vacuum advance is a cone shaped unit on the side of the dist, it goes down to a tip for the vac line. if you take the cap off you can see the mechanism it operates. maybe since this is for a boat it didn't have one. i am not familar with them but if it doesn't have it i would think you will need to get a dist with one on it to work in a truck. maybe the boat only opperates at fixed rpm's and doesn't need it. also don't some boat engines spin in reverse rotation? good luck. | | | | | Joined: Mar 2009 Posts: 100 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 100 | thanks, the only thing thats keeps puzzeling me is the truck ran great for 45 miles.
| | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | My guess is....Too rich and timing not advanced/advancing far enough. | | | | | Joined: Mar 2009 Posts: 100 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 100 |
| | | | | Joined: Nov 2008 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2008 Posts: 48 | OK. You got MY attention when you said the motor is out of a boat! What is the year model of the engine and the displacement? Did the distributor come with the engine? If it did, most industrial engines used a governor and the distributor does not have a vaccume advance on it.
Also to note: The 250ci. industrial engines used a higher compression ratio ( 8.7 : 1 ) and larger valves. With the HEI distributor upgrade, a 2 bbl carb, and crane cam, they are a real hoss of a motor!
tp://s367.photobucket.com/albums/oo113/RED64STEPSIDE/
| | | | | Joined: Mar 2009 Posts: 100 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 100 | I will find thoes answers for you. I just bought the truck 3 weeks ago and i am not sure the motor size or year. It does say GM12 on it with some other numbers. I would imagine the distributor came with the engine. But this still begs the questions or statement that it ran perfect for the firast 45 miles i owned it, and then abrubtly quit. Thanks for your interest maybe we can get this figued out.
| | | | | Joined: Feb 2004 Posts: 29,746 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,746 | Since marine engines do not change throttle loads like a car, there's no need for a vacuum advance. I'd suggest getting a regular distributor, a HEI if possible, as the marine dizzy won't work well in a road vehicle. It sounds like you've got some major carburetor problems that came on pretty suddenly, possibly a flooding situation caused by dirt under the needle valve, etc. Jerry
| | | | | Joined: Mar 2009 Posts: 100 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 100 | It can't be a carb problem i have put a new one on since it started. I adjusted the timing a little richer last night and it has vastly improved the problem. I can know drive it at least. It still has a little vacuum sound when the pedal is pressed real quick, but I think we are getting closer. I am going to make sure i get the engine details, and then i will adjust the timing properly and reset the points and see if that fine tunes it back to the way it was running. I will also look twoards getting an automotive distributor once i do get the engine details. Thanks for the help we are so close.
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Have you checked your point gap. It may have slipped on you. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Mar 2009 Posts: 100 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 100 | here is the big reveal
The motor did come out of a boat, it is the same motor as the 67 chevy bisycane, except that the distributor does not have a vacuum advance like HotRod Lincoln said. It is a 250 ci motor. So for the most part it is the same as the 292 that was in the truck orginally, except the block on the 250 is 2" shorter.
I am going to buy a distributor for a 67 bisycane (37 dollars) and then i should have the vacuum advance port for the caburetor hook up done. Then i am going to redo the timing and reset the point gap.
Hopefully my last question is what are you guys setting the point gap and spark plugs at for the 250 or 292 enignes.
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I'm not saying this because I have one for sale. I believe most of the fellow stovebolters will agree. Now would be a good time to put an HEI dist. in, or at least an electronic ign. conversion kit. You can probably find one locally. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Mar 2009 Posts: 100 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 100 | I just drove it to the gas station and it drove good but it is blowing a light black smoke out of the back. Any ideas on what adjustment i need to make. I am thinking maybe its the fuel/air mixture screw on the carb.
Thanks Again
| | | | | Joined: Nov 2008 Posts: 355 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 355 | well from what i understand white to light to lt blue smoke is bad rings, but black smoke usually indicates over rich carb you might try leaning the mixture out some and see if that dosn't cure the prob "much better to have black smoke than white lol"
1937 1/2 ton
| | | | | Joined: Mar 2009 Posts: 100 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 100 | thanks i will update later
| | | | | Joined: Feb 2000 Posts: 5,191 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,191 | The mixture screw only works at idle, to change off-idle mixture you will need to re-jet. I would get some miles on it before worrying to much. It could be loaded up for all the tuning you have been doing. Get a HEI or new points distributor, get it timed where it doesn't ping under a medium load (6-10 degree) then get it out on the highway. A good 10 mile drive will clean out a lot crud and dry out the plugs. If it still smokes, we can go from there. Joe | | | | | Joined: Mar 2009 Posts: 100 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 100 | Joe,
Great Advice. I will do that this week and update the post accordingly. Thanks for help.
