1 members (Otto Skorzeny), 58 guests, and 3 robots.
Topics128,022
Posts1,055,381
Members48,422
#526459 04/09/2009 5:02 AM
I'm working on replacing the blocks between the bed and frame.(52 3100)the front blocks sit right on the frame,but the ones in the back are inside sheetmetal spotwelded to the rear crossmember? do I just bend the metal up or grind them off?
joes1952 #526492 04/09/2009 7:34 AM
Hi joeat50,
Your truck is a 52,as far as I'm aware the rearmost mounts don't have the wood blocks,just a rubber pad.
The front and mid crossmembers use the wooden blocks.
My 50 was original and unmolested and had no wood at the rear.
I remember seeing a post a while back regarding bed mounting,try a search and you may find it.
I would have done it myself and posted the link,but I have to get ready for work! dang
More pix on Flickr.
jockbolter50 #526512 04/09/2009 1:12 PM
Mine is the same as Jock's
Tim
1952 Chevy Shortbed
Photos in Photobucket
SW_Radial #526537 04/09/2009 2:10 PM
I think Mar-K has instructions that may show what you need....try their link....but I jock and radial have answered your question.
