1 members (‘37ChevyPU), 86 guests, and 3 robots.
Topics128,211
Posts1,057,476
Members48,473
I bought a new gas pedal. Appears i am missing some pieces to complete the job. Their is a piece at the base of that gas pedal that looks like it bolts to some sort of ball socket. Any help would be great thanks.
Looking for panel or suburban in excellent shape. Long time hotrodder.
Leo Offline
Moderator
Moderator
My '53 has a pivot pin that goes through a bracket on the floor. No ball socket.
The gas pedal they sent me goes on the ball on the end of the throttle linkage then down to like a u shaped piece that would accept a bolt. Mounted on the floor is a bracket thats flat and looks like some sort of ball goes into it. Anyone give me a clue?
Pictures really help in these kinds of situations!
akroadzombies,
Your description is correct. In 1953-1957, the ball at the top of the linkage-rod goes into a socket at the top of the pedal, and there is a pin/rod that goes through through the holes on the sides of the bracket on the floorboard and through the the bracket at the base of the pedal.
Tim
Man looks like their is something missing there. Would be awesome to see some pictures for sure. Went thru some old manuals and cant find any pictures of that area. Thanks
I'm not sure if this applies but my '52 has a plate or bracket that looks like this
The picture doesn't show the whole bracket but it has two holes with a pin that holds the base of the pedal to the floor. Hope this gives you some perspective.
