| | | Forums66 Topics128,211 Posts1,057,472 Members48,473 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2009 Posts: 12 New Guy | | New Guy Joined: Feb 2009 Posts: 12 | I bought a new gas pedal. Appears i am missing some pieces to complete the job. Their is a piece at the base of that gas pedal that looks like it bolts to some sort of ball socket. Any help would be great thanks.
Looking for panel or suburban in excellent shape. Long time hotrodder.
| | | | | Joined: Mar 2007 Posts: 4,217 Moderator | | Moderator Joined: Mar 2007 Posts: 4,217 | My '53 has a pivot pin that goes through a bracket on the floor. No ball socket. | | | | | Joined: Feb 2009 Posts: 12 New Guy | | New Guy Joined: Feb 2009 Posts: 12 | The gas pedal they sent me goes on the ball on the end of the throttle linkage then down to like a u shaped piece that would accept a bolt. Mounted on the floor is a bracket thats flat and looks like some sort of ball goes into it. Anyone give me a clue?
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Pictures really help in these kinds of situations! | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | akroadzombies, Your description is correct. In 1953-1957, the ball at the top of the linkage-rod goes into a socket at the top of the pedal, and there is a pin/rod that goes through through the holes on the sides of the bracket on the floorboard and through the the bracket at the base of the pedal. Tim | | | | | Joined: Feb 2009 Posts: 12 New Guy | | New Guy Joined: Feb 2009 Posts: 12 | Man looks like their is something missing there. Would be awesome to see some pictures for sure. Went thru some old manuals and cant find any pictures of that area. Thanks
| | | | | Joined: Jun 2007 Posts: 120 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2007 Posts: 120 | I'm not sure if this applies but my '52 has a plate or bracket that looks like this The picture doesn't show the whole bracket but it has two holes with a pin that holds the base of the pedal to the floor. Hope this gives you some perspective. | | |
