0 members (),
115
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,113 Posts1,056,619 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2007 Posts: 230 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 230 | How do I get the inside door and window handles off ? There is probably a spring clip somewhere, right ? Is there a special tool I need ? Does anyone have a picture of the parts ? Thanks in advance. | | | | | Joined: Oct 2008 Posts: 321 'Bolter | | 'Bolter Joined: Oct 2008 Posts: 321 | In both cases there is a set screw holding the handles on. Look where the main part of the handle comes off the part that mounts to the door. That's where the set screw is. Loosen up the set screw and those handles will pop off. Oh, and the screws are common, slotted, regular..... whatever you like to call them. Hope I made that clear as mud
1963 Chevy C20 Longbed Stepside 1978 Chevy K30 Custom Deluxe
| | | | | Joined: Feb 2007 Posts: 230 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 230 | Thanks. What you are saying is that the set screw is on the inside back of the handle ? | | | | | Joined: Oct 2008 Posts: 321 'Bolter | | 'Bolter Joined: Oct 2008 Posts: 321 | Yes, that is what I'm saying. I'm glad you were able to follow that, sometimes I'm horrible at explaining stuff...lol
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Tim, be mindful there may be TWO screws in the handles. I've ran into this before. I've taken one out and then jerked and jerked on the handle only to find another still up in there!! Seems someone had a door handle coming loose and put another screw in it to help keep the other from backing out. I've seen this two or maybe three times in the past couple years. | | |
