0 members (), 83 guests, and 0 robots.
Topics128,115
Posts1,056,292
Members48,439
Junior Member
Junior Member
I'm looking to buy a farm fresh 1967 4x4. The previous owner told me that the front U-joints are loose, and should be checked out before I do anything but farm driving.
Does any one know how involved and expensive it would be to replace the steering U-joints. Front ball joints are shot too.
The truck is mostly straight with a little rust and a 283.
Tell me what you think
pictures are at the link below.
http://pg.photos.yahoo.com/ph/boundstaffpress/album?.dir=/162f&urlhint=actn,ren%3as,19%3af,0
More Later
Justin
The front "steering" joints in the front axle are replaced as you would a standard driveshaft u-joint. The ball joints are a little tougher. You'll need a special socket to set-up the preload on the upper joint and access to a press or a ball joint press to remove and install the joints into the spindles. Take your time and you'll get it,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
Junior Member
Junior Member
Thanks Scott.
I found out since that this truck doesn't have ball joints. 4x4 truck have a straight axle with a type of roller bearing king pin on top and bottom.
More Later
Justin
That's what I'm talking about too, I just went through mine,
Scott
Scott Ward
1 1950 3100
1 1963 K20 (454)
1 1964 C10 (350)
Junior Member
Junior Member
If I have to have a press, I'll just take it to my mechanic. Have him align it when he's done.
More Later
Justin
