8 members (1955 1 Series, klhansen, John Dlugos, Bill Hanlon, Gray_Ghost, Otto Skorzeny, 2 invisible),
219
Mod | | | Forums66 Topics128,101 Posts1,056,179 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#52387 11/14/2005 7:03 PM | Joined: Oct 2005 Posts: 10 Junior Member | | Junior Member Joined: Oct 2005 Posts: 10 | I'm looking to buy a farm fresh 1967 4x4. The previous owner told me that the front U-joints are loose, and should be checked out before I do anything but farm driving.
Does any one know how involved and expensive it would be to replace the steering U-joints. Front ball joints are shot too.
The truck is mostly straight with a little rust and a 283. Tell me what you think
pictures are at the link below. http://pg.photos.yahoo.com/ph/boundstaffpress/album?.dir=/162f&urlhint=actn,ren%3as,19%3af,0
More Later
Justin
#52388 11/15/2005 12:58 AM | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | The front "steering" joints in the front axle are replaced as you would a standard driveshaft u-joint. The ball joints are a little tougher. You'll need a special socket to set-up the preload on the upper joint and access to a press or a ball joint press to remove and install the joints into the spindles. Take your time and you'll get it, Scott | | |
#52389 11/15/2005 5:33 PM | Joined: Oct 2005 Posts: 10 Junior Member | | Junior Member Joined: Oct 2005 Posts: 10 | Thanks Scott.
I found out since that this truck doesn't have ball joints. 4x4 truck have a straight axle with a type of roller bearing king pin on top and bottom.
More Later
Justin
#52390 11/15/2005 7:16 PM | Joined: Mar 2005 Posts: 92 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 92 | That's what I'm talking about too, I just went through mine, Scott | | |
#52391 11/15/2005 11:22 PM | Joined: Oct 2005 Posts: 10 Junior Member | | Junior Member Joined: Oct 2005 Posts: 10 | If I have to have a press, I'll just take it to my mechanic. Have him align it when he's done.
More Later
Justin
