3 members (cmayna, Ponchogl, Hotrod Lincoln), 105 guests, and 0 robots.
Topics128,126
Posts1,056,351
Members48,441
#52355 11/14/2005 1:11 AM
All, I am now tired of living in the slow lane and want to upgrade my gear ratio. Only problem is I don't know what rear-end ratio I have now. The vehicle is a 54 3100 with a 235 and Hydramatic four speed. I believe the rear end is stock. When I ring her out I can get about 65 according to my speedo, but cannot cruise at more than 55 without fear of blowing something. How can I figure out what ratio I've got and what I need?
Bruce (I love My Truck) Miller
1954 5 Window 3100 Chevy Pickup - Driver
1929 **** Model A Pickup - Restoration
#52356 11/14/2005 4:15 AM
If you have the stock 1/2 ton rear end, it's a 3.90:1 gear ratio. Sounds right as per your description too. You can get the 3.55:1 ratio ring & pinion kit to be able to cruise @ 65. Chevy Duty Part # 93-511 Good luck.
#52357 11/14/2005 11:46 AM
Don't forget,you can get about the same overall benefit from changing from 28" diameter tires to 31" tires as from changing your 3.90 ratio to a 3.55,and it won't cost you near as much in labor.Or,if you went for both changes,at 65 mph,your rpm's would drop from 3,050 to 2,500.
Just something to think about.
Speed
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
