2 members (wilbur53, Otto Skorzeny), 39 guests, and 2 robots.
Topics128,037
Posts1,055,465
Members48,422
#522253 03/29/2009 4:31 PM
Is there a trick I don't know about? My problem is that there is not enough room between steering wheel and column shifter I keep knocking it outta gear or just raking knuckles through it. Panel still doesn't have brakes but it's just to fun to drive and the chickens have learned to run when they see me.
Riding in the Passing Lane
What year? 57 up had a recessed steering wheel. If you have an older wheel on one it would be real awkward.
1972 Chevy c10 Cheyenne Super
it's a 53 and the wheel is fairly flat. It might have an inch of clearance between wheel and shifter while in first or reverse. It's difficult to turn in low gear because my knuckles do not pass through easily.
Maybe Alvin can come over to look at it and tell you what's wrong,if he can find the time.
_____________
Floyd
If we choose being kind over being right,we will
be right every time.
Knowledge is a poor substitute for experience.
Remember what is precious to another, may not be to you, but it
is precious nonetheless.
1948 Chevy 2-Ton
Went by Thursday, tnttruck, but he was not there.....BUT he did come by the house today. A real nice young man and has a good bit of mechanically knowledge..and his lady also is pretty dang sharp on stuff. I told him to hang onto her smile
I'm going to go by one evening this week. I also want to look at a couple things on his Original panel!!
Isn't stovebolting grrreat!
"chickens have learned to run when they see me." I always refer to them as pedestrians. grin
~Jim
figured out the problem while rolling around under it tonight. someone slid the the shift box and rod further up the column to clear the intake manifold on the 235 thus putting the lever closer to the wheel.
