0 members (),
139
Mod | | | Forums66 Topics128,167 Posts1,057,021 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#52204 11/11/2005 2:20 AM | Joined: Jan 2004 Posts: 58 Member | | Member Joined: Jan 2004 Posts: 58 | Being a Police Officer I have been out of the site for a while since all the hurricanes have hit our great nation and I've visited many states. Now Im back and ready to get greasy again. Question! I need to change my flywheel from 6v to 12v, would it be easier to pull the engine or lower the tranny. The drive train bar(I think it's called this)is incased in a tube. Is it easy to remove? Special tools? Thanks in advance. Jorge :rolleyes:
#52205 11/11/2005 2:26 AM | Joined: Aug 2004 Posts: 1,418 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,418 | Why do you need to change the flywheel? IF you are converting to 12V a 6V starter will still work....
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | |
#52206 11/11/2005 2:29 AM | Joined: Oct 2005 Posts: 37 Junior Member | | Junior Member Joined: Oct 2005 Posts: 37 |
1951 6400 1954 6100 dump 2 1962 IHC scouts
#52207 11/11/2005 2:34 AM | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | A six volt starter will work just fine on 12V. Why change anything? | | |
#52208 11/11/2005 2:40 AM | Joined: Jan 2004 Posts: 58 Member | | Member Joined: Jan 2004 Posts: 58 | Everyone keeps telling me that but it won't 3 starters to boot. It grinds for the first couple of starts then bam! nothing. I rebuilt the 1955 235 and can't start it. The starter makes a horrible noise then dies. Im about ready to sell the truck I drive it 2 weeks in between starters. I have to push start it now! | | |
#52209 11/11/2005 2:40 AM | Joined: Oct 2005 Posts: 37 Junior Member | | Junior Member Joined: Oct 2005 Posts: 37 | As long as your engine starts quickly there is no problem, but if you have to crank for even a few extra seconds it will eventualy burn up the windings. That is when you convert to 12 volt.
#52210 11/11/2005 2:43 AM | Joined: Jan 2004 Posts: 58 Member | | Member Joined: Jan 2004 Posts: 58 | I counted the teeth and was told it was a 6v flywheel. I have converted it to key start. When I get the starter I sometimes have to move the fan a couple turns for it to fall into gear then it starts. if not it grinds, spins, ???? Im frustrated. | | |
#52211 11/11/2005 2:45 AM | Joined: Jan 2004 Posts: 58 Member | | Member Joined: Jan 2004 Posts: 58 | It has never started quickly! Is it a VW thats funny!!lol | | |
#52212 11/11/2005 2:51 AM | Joined: Jan 2004 Posts: 58 Member | | Member Joined: Jan 2004 Posts: 58 | were can i find a 6v starter with a selenoid? | | |
#52213 11/11/2005 3:09 AM | Joined: Aug 2001 Posts: 1,300 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 1,300 | I have been running a 6V starter on 12V for 25 years or better. I think you must have another problem. I recently switched to solenoid start and put a 12V solenoid on my 6V starter and I believe that to be sound advice. A 6V solenoid I am told will hit flywheel too hard on 12V and damage ring gear teeth. Usually, with a 6V starter on 12V the engine turns over fast enough that it is running before starter has to turn much at all. Could you have bad battery/starter cables causing too much current? | | |
#52214 11/11/2005 3:20 AM | Joined: Jan 2004 Posts: 58 Member | | Member Joined: Jan 2004 Posts: 58 | I know for a fact I have a 6v flywheel, and 12v starter with seleniod. I installed new cables, battery and it grinds everytime I was told that I needed to install a 12v flywheel which has more teeth. or get a 6v starter. | | |
#52215 11/11/2005 3:26 AM | Joined: Jan 2004 Posts: 58 Member | | Member Joined: Jan 2004 Posts: 58 | What should I do! Change the flywheel to a 12v or search for a 6v starter with a seleniod, since I do not have foot start mechanism I need a seleniod to key start correct! | | |
#52216 11/11/2005 3:28 AM | Joined: Dec 2002 Posts: 571 Shop Shark | | Shop Shark Joined: Dec 2002 Posts: 571 | That is correct! Prolly easier to change the starter. A lot easier! Good luck | | |
#52217 11/11/2005 3:32 AM | Joined: Jan 2004 Posts: 58 Member | | Member Joined: Jan 2004 Posts: 58 | what I just buy a six volt starter with a seleniod? Any suggestions were to get one? thanks Jorge | | |
#52218 11/11/2005 3:33 AM | Joined: Dec 2002 Posts: 571 Shop Shark | | Shop Shark Joined: Dec 2002 Posts: 571 | Oh, don't know bout the 6 volt selenoid. Sorry. I have all the mechanicals if you want to make it a foot start though.  | | |
#52219 11/11/2005 3:34 AM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | this isn't a situation of converting to 12V guys - what Jorge is saying is he put a later 12V solenoid actuated starter on a 6V 'flywheeled' engine, not the 6V foot stomp, so yes, a later ring gear is needed on the flywheel, or a complete later flywheel needs to be found - try a post in the parts wanted, Jorge, for a 56+ 235 flywheel
to pull the flywheel you'll have to drop the "bar" [torque tube style drive shaft] and pull the trans, which will be much easier than pulling the engine w/ the trans left behind
Bill edit: you won't find a 6V solenoid actuated starter | | |
#52220 11/11/2005 3:40 AM | Joined: Jan 2004 Posts: 58 Member | | Member Joined: Jan 2004 Posts: 58 | Wow' thanks, sorry I wasn't explaining myself correctly. Thanks guys!! Going to the wanted ads right now! | | |
#52221 11/11/2005 4:36 AM | Joined: Aug 2001 Posts: 1,300 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 1,300 | Next question: will a 6V starter drive fit in his 12V starter? The number of teeth are determined at the starter drive. | | |
#52222 11/11/2005 2:03 PM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | This seems to be a mismatch with a 12v starter, six volt flywheel , both with different pitch on the teeth. My first question would be is the ring gear badly damaged? After that you would then know if there is any chance of correcting it without pulling the tranny. | | |
#52223 11/11/2005 5:36 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | It seems a 49-54 car starter would be 6 volt with a selenoid. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#52224 11/11/2005 6:43 PM | Joined: Mar 2002 Posts: 384 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 384 | I have a 55.1 which would have been made with a 6 volt. It has a solenoid starter. It may just be a matter of switching the gear on the starter with a gear from a 6 volt starter and installing the 12 volt. I think my starter came from a 12 volt 6 cyl car. Change the little gear. It seems foolish to go to the trouble of changing the flywheel. - Scott
55 1st Chev.
#52225 11/16/2005 8:00 PM | Joined: Jun 2005 Posts: 887 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 887 | The older 6v engines had a 6v starter with lets say 32 teeth (maybe it was 28?) The later 12v engines and starters used a ring gear with more teeth, lets say 40. Both used the same bellhousing. A later 12v starter will bolt right up to an older engine but will not work right 'cause it won't mesh and will eventually chip the teeth on your ring gear. Same works the other way, 6 volt starter on 12 volt engine causes problems.
The right thing to do is to count the teeth on your ring gear, figure out which starter you must use, 12v or 6v, and then order one. NOW... there are 6v starters converted to 12v. Yup... they have the right number of teeth but run on 12v! Check with all the different parts houses-ie chevy duty, jim carters, chev's of the 40s, LMC, Patrick's, Langodon's, and others.
The 6v starter will work with 12v of juice but eventually will burn up. So, lots of people who convert their trucks to 12v use the 6v starter til it goes and then buy the right 12v replacement.
If you've used the wrong starter, chances are the teeth on the ring gear are ground up/chipped and the ring gear needs to be replaced. That means, pull the transmission, pull the pressure plate and clutch, pull the flywheel and put on a new ring gear before putting the flywheel, clutch assembly and transmission back in. Replacing the ring gear isn't too hard once you've got the flywheel infront of you, just knock off the old one, heat up the new one to make it expand a little and put it onto the flywheel.
If you've got to replace the ring gear, you might as well check the run out on the flywheel clutch surface and turn/re-face as necessary, check the pressure plate, clutch disc, pilot bushing/bearing, throw-out bearing, clutch arm pivot ball, gaskets and fluid in the transmission, and the universal joint of your torque tube (where it bolts to the back of the tranny).
If your ring gear is messed up, you might be in for a big project!
#52226 11/16/2005 8:33 PM | Joined: Jun 2005 Posts: 887 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 887 | PS-
If you've got a good starter that doesn't match a messed up ring gear, no reason not to match the ring gear to the existing starter.
#52227 11/16/2005 9:27 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Post on the swap meet parts wanted for a 6 volt car starter/w selinoid. Someone surely has one laying around. That would be a lot easier than changing flywheels. 6 volt starters last longer on 12 volts than 6. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
