| | | Forums66 Topics128,264 Posts1,058,350 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#77159 05/06/2007 4:46 PM | Joined: Feb 2007 Posts: 33 Apprentice | | Apprentice Joined: Feb 2007 Posts: 33 | Which red for the color of a 1955 ist series gmc 248 from a 1/2 ton. Carter's says gmc redorange which doesn't sound right. I have seen gm crimson red as a notation. Should I prime the parts? Insides of the sheet metal stay metal or do they get paint? Bell housing the same as the block? Should the mating surfaces be painted and then assembled? Contrasting bolt colors or build it up and shoot the whole thing gasket sides and all?
I expect the starter/generator/fan brackets to be black. Which black? Thanks for the advice.
Paull | | |
#77160 05/06/2007 5:30 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The Chev orange/red is deffinitly wrong. It was a deeper red like Crysler or Buick. I use primer on bare metal surfaces & Rustoleom rusty -metal- primer on rusted surfaces. Don,t paint the inside. If it comes loose it can clog oil passages. I believe the bell housing was not painted from the factory. Duplicolor has a paint called builders cast coat. It looks like cast iron. I lke to assemble the engine & paint it all. On the pulleys & brackets etc. use Ace hardware premium in a black can. Semi-flat black.Krylon also has a semi-flat black but it is duller. I use it under fenders & core supports & inner fenders. Now after you spend about 50 bucks on aerosols you will have a whole cabinate full like I do. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#77161 05/06/2007 7:03 PM | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Crimson Red is the correct GMC engine color from 1951-1958. GM code was 514. Dupont Nason 54701BD in urethane. | | |
#77162 05/09/2007 4:00 AM | Joined: Feb 2007 Posts: 33 Apprentice | | Apprentice Joined: Feb 2007 Posts: 33 | Carter sent me orange 49-59 6cyl bar code pt118 3051. I think this in incorrect color. Anyone try this with success, this seems like valve cove paint of the 60's. Chevrolet v8 manifold color. | | | | | Joined: Feb 2007 Posts: 33 Apprentice | | Apprentice Joined: Feb 2007 Posts: 33 | GMC Now I am doing a 53 228 engine. I feel the crimson red is correct but the Filling Station lists the dark grey as authentic for this engine. Any help? | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | I think gray was the color of Chevy 216, 235, 261s. GMC should be red as mentioned above. I paint all the parts before they go together with the exception of internal mating services. All the bolts I use get a clear coat on them and most everything still looks good like that. Once finished I touch up stuff by hand with a small detail brush.
Jeff | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | pgossett,
What is the part number for the Filling Station GMC 228 engine paint? I find their search feature difficult to use and only see Chevy engine paints.
Tim
| | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | Others may argue, but the rattlecan duplicolor 1607 was almost a perfect match to the to the original engine paint on my 59 270. The shade of that crimson red varied from plant to plant and day to day. | | | | | Joined: Feb 2009 Posts: 37 'Bolter | | 'Bolter Joined: Feb 2009 Posts: 37 | What is the pre-1951 GMC 228 engine color? I'm going to be painting an engine for a 1946 1/2 ton. | | |
