4 members (Jon G, Gray_Ghost, Bill Hanlon, MRMEROTH11), 85 guests, and 0 robots.
Topics128,068
Posts1,055,881
Members48,428
#520496 03/24/2009 8:18 PM
I have a 1951 3100 with 216cid, It runs fine and I have had
all the body work done and want to make it a driver. I have
read all about how to get more speed out of the 235 and can
find add-on intakes to put 4 barrelcarb on. But can't find
any info on 4 barrel intake for a 216, or are the both the same?
any help or ideas would be much appreciated
dave johnson #520498 03/24/2009 8:39 PM
Contact Stoveboltengineco.com
The 216 according to all cannot handle anything more than the Carb it came with .
The 235 has so many advantages for power and upgrades .
Just my observation
just-a-hacker
'49 3100 before '99
Dave, best thing you can do for more highway speed is get a higher rear end gear or overdrive trans. The 235 intake can work on your 216, has slightly larger intake runners, I ran one on my 261 for many years. But the 235 intake will not mate up to your stock 216 exhaust, so you can use fentons or just use a 235 exhaust.
Also you may want to check out www.inliners.org
1946 1/2-Ton Chevy
Jim. Thanks for your help. but let me aske you. what about a
Offenhouser or Fenton setup for a 235, will that work on a 216 ??
dave johnson #520899 03/25/2009 10:22 PM
In it's time, Offenhauser made a 2 carb intake for the 216 as well as the 235, but they are not the same as there is a difference in intake port diameter.The 216 has smaller ports.I think the Offy part numbers were: 216=1032 235=1034 I'm not sure how today's repros are numbered.
Drew
DrewP #520909 03/25/2009 10:47 PM
Jim. thanks again. but what rear end do I have and what would I
change to?
dave johnson #520957 03/26/2009 12:44 AM
The original 1951 3100 rear end is a 4.11
Use the search feature on +3.55 +rear and you will find a lot to read about a common rear end conversion.
tclederman #521007 03/26/2009 2:25 AM
Patrick's catalog lists a 2x1 Offy for a 216 part #1034 also list 3:55 ratio rear end gears for your truck. You need to get their catalog, lots of GOOOOOD info. 216 intake is a bit of a different animal than one for a 235 but both will bolt up as I said. I'd just start collecting catalogs from ALL the vendors so you can see what's out there. Patrick's, Langdon's Stovebolt, Chevs of the 40s etc etc. And read this entire website/tech tips and the same over at Inliners.org.
1946 1/2-Ton Chevy
