| | | Forums66 Topics128,069 Posts1,055,896 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 25 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 25 | I have a 1951 3100 with 216cid, It runs fine and I have had all the body work done and want to make it a driver. I have read all about how to get more speed out of the 235 and can find add-on intakes to put 4 barrelcarb on. But can't find any info on 4 barrel intake for a 216, or are the both the same? any help or ideas would be much appreciated | | | | | Joined: Nov 2008 Posts: 465 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 465 | Contact Stoveboltengineco.com
The 216 according to all cannot handle anything more than the Carb it came with .
The 235 has so many advantages for power and upgrades .
Just my observation
| | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Dave, best thing you can do for more highway speed is get a higher rear end gear or overdrive trans. The 235 intake can work on your 216, has slightly larger intake runners, I ran one on my 261 for many years. But the 235 intake will not mate up to your stock 216 exhaust, so you can use fentons or just use a 235 exhaust. Also you may want to check out www.inliners.org | | | | | Joined: Dec 2006 Posts: 25 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 25 | Jim. Thanks for your help. but let me aske you. what about a Offenhouser or Fenton setup for a 235, will that work on a 216 ?? | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | In it's time, Offenhauser made a 2 carb intake for the 216 as well as the 235, but they are not the same as there is a difference in intake port diameter.The 216 has smaller ports.I think the Offy part numbers were: 216=1032 235=1034 I'm not sure how today's repros are numbered.
Drew
| | | | | Joined: Dec 2006 Posts: 25 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 25 | Jim. thanks again. but what rear end do I have and what would I change to? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | The original 1951 3100 rear end is a 4.11
Use the search feature on +3.55 +rear and you will find a lot to read about a common rear end conversion.
| | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Patrick's catalog lists a 2x1 Offy for a 216 part #1034 also list 3:55 ratio rear end gears for your truck. You need to get their catalog, lots of GOOOOOD info. 216 intake is a bit of a different animal than one for a 235 but both will bolt up as I said. I'd just start collecting catalogs from ALL the vendors so you can see what's out there. Patrick's, Langdon's Stovebolt, Chevs of the 40s etc etc. And read this entire website/tech tips and the same over at Inliners.org. | | |
