4 members (Otto Skorzeny, Gdads51, Opelika Tom, crenwelge), 75 guests, and 1 robot.
Topics128,062
Posts1,055,851
Members48,428
#52027 11/06/2005 5:09 PM
Does anyone know how to attach a stock shifter to a SM420 tranny? I recently did a swap from a 3-speed to a 4-speed and am trying to install the shifter. The top of the transmission has 2 holes on either side where it would seem 2 pins would fit to hold the shifter in place, but there were no pins in the tranny when I got it.
I tried using 2 roll pins (5/16") but they were too big to fit in the hole. 1/4" would seem to be too small
Does anyone know what to use?
Thank you
Adam
stovebolt2355
http://www.stovebolt2355.com
#52028 11/06/2005 5:21 PM
It's not held in by pins. To remove shifter, you would press down on the ball with both thumbs and twist. And it'll pop out. Installation is reverse procedure.
-David
Tradin' up dimes for nickels...
My \'65 Chevy C-20
#52029 11/06/2005 5:49 PM
What locks the ball in place? I see how you are supposed to twist the ball after pressing down, but there is nothing on the tranny to lock it in place.
Adam
Adam
stovebolt2355
#52030 11/06/2005 6:00 PM
There should be two pins on the collar of the tranny, it sounds like yours are missing.
They are larger in diameter inside the collar and appear to be peened over to keep them from falling in to the gear box
#52031 11/06/2005 6:06 PM
Are these pins available anywhere or can something else be used instead?
Adam
Adam
stovebolt2355
#52032 11/06/2005 11:58 PM
Riding in the Passing Lane
Find the right size roll pins. They will tap in the holes. If you don.t find any e-mail me an address & i,ll send some. I,ve got a whole bag of them. [email protected]
1972 Chevy c10 Cheyenne Super
#52033 11/07/2005 2:41 AM
V
V Offline
I've tried roll pins, they wear out quickly. You need to get the stock ones. You may still be able to order them from GM. You can also contact places like National Drivetrain, they can get them for you.
#52034 11/11/2005 1:09 AM
Though it's not the best shot, in the following pic you'll see the two pins in question.
SM420 top plate
Craig
#52035 11/11/2005 5:48 AM
I bought mine from the local Chevy dealer. They used the same parts for this purpose for decades.
speed
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
#52036 11/13/2005 4:47 AM
Thanks for the advise. The local Chevy dealer did not have any of the pins and they said that GM does not make them any more.
I ended up having my grandpa make 2 pins on the lathe and they seem to work perfectly. I will see how long they last.
Adam
Adam
stovebolt2355
