6 members (Bill Hanlon, 54farmtruck, KEVINSKI, 1955 1 Series, jay d, NofoolN), 102 guests, and 3 robots.
Topics128,186
Posts1,057,315
Members48,469
have installed power brakes 1 year ago. when my truck sits a couple of days, I have to pump them to get a pedal. I have bled them a number of times. This brings the pedal back up , until I let it set agian. My first thought was a bad master cylinder, I changed to a new one last week. Drove yesterday, same problem!! I have completly checked all lines and fittings, no leaks..Any ideas? thanks
Not sure what kind of truck you have. Does it have a hydro-vac on it? Or a booster? Or what?
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
the truck has power brakes with a brake booster
What truck? What year, size, etc.,
Scott
Scott Ward
1 1950 3100
1 1955.1 Chevy 6500
1 1963 K20 (454)
1 1964 C10 (350)
what year truck ?
firewall mounted booster and master or floor mounted ?
all drum, or front disc ?
if floor mounted you will need to run residual valves for front and back.
http://www.ecihotrodbrakes.com/brake_facts.html
http://www.ecihotrodbrakes.com/images/pic03_brakefacts.gif
http://www.ecihotrodbrakes.com/images/pic04_brakefacts.gif
hope this helps...
leonard
1957 Chevy 3100 1/2-Ton
Photobucket pictures
The vacuum line to the manifold should have a one-way check valve that holds vacuum pressure for the brakes. Sounds like that may be leaking down. I'd start by replacing that. They usually are just pushed into the rubber vaccum line, you can feel it if you start squeezing the rubber tube...
R-Bo
1966 GMC 305V6 in the family
