7 members (Chip O, 1955 1 Series, Gray_Ghost, JoergK., Peggy M, oldieoldie, 1 invisible),
177
Mod | | | Forums66 Topics128,191 Posts1,057,348 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 49 New Guy | | New Guy Joined: Nov 2008 Posts: 49 | have installed power brakes 1 year ago. when my truck sits a couple of days, I have to pump them to get a pedal. I have bled them a number of times. This brings the pedal back up , until I let it set agian. My first thought was a bad master cylinder, I changed to a new one last week. Drove yesterday, same problem!! I have completly checked all lines and fittings, no leaks..Any ideas? thanks | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Not sure what kind of truck you have. Does it have a hydro-vac on it? Or a booster? Or what? Scott | | | | | Joined: Nov 2008 Posts: 49 New Guy | | New Guy Joined: Nov 2008 Posts: 49 | the truck has power brakes with a brake booster | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | What truck? What year, size, etc., Scott | | | | | Joined: Feb 2007 Posts: 434 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 434 | The vacuum line to the manifold should have a one-way check valve that holds vacuum pressure for the brakes. Sounds like that may be leaking down. I'd start by replacing that. They usually are just pushed into the rubber vaccum line, you can feel it if you start squeezing the rubber tube...
R-Bo
1959 Apache 1/2 ton Big Window, Short bed Fleetside (under reconstruction) 1966 GMC 305V6 in the family
