| | | Forums66 Topics128,085 Posts1,056,091 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#51868 11/03/2005 10:00 PM | Joined: Nov 2005 Posts: 41 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 41 | I am preparing to remove the engine/tranny from my new project. It looks like it is going to be a very tight squeze. Can the combo be removed or do I need to remove the tranny first?
Chevy Pete
#51869 11/03/2005 11:02 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I like to pull the trans. first unless you have a lot of the body parts off anyhow. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#51870 11/03/2005 11:28 PM | Joined: Nov 2005 Posts: 41 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 41 | I have pulled the radiator and support, fan, generator, grill, engine shock mount bolts and top tranny cover. My shop manual is for a 51 with a 52 suplement and it was silent on removing the tranny first. Unless someone has some other advice I think removing it would be the fastest way out.
Chevy Pete
#51871 11/04/2005 1:44 AM | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | With the front end sheetmetal gone I see no reason why you need to remove the transmission. I assume it is a 4 speed. On the other hand it is not really all the difficult to unbolt the tranny from the bellhousing and leave it in the chassis. Either way would work OK. | | |
