Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
0 members (), 37 guests, and 5 robots.
Topics128,009
Posts1,055,293
Members48,419
#517162 03/14/2009 10:58 PM
I'm having problems with my 66 gmc doors shutting all the way, I have adjusted the latch and door striker again and again but the door will either bounce back and not shut or latch too loose and not be flush, anybody have this problem or is there a usual suspect to fix or change?
todjob2000 #517166 03/14/2009 11:31 PM
if you've recently installed new rubber seals, I'd suspect they're not a good match for original thickness and material - also might try adusting from the hinge side as well as the latch side, the doors may be in too far there
Flxible #517417 03/15/2009 6:00 PM
I have seen lots of these trucks have these same door issues, even without replacing the seals. I am going through this with the left door of my '63 right now. If I come across the ultimate fix I'll be sure to post it.
1963 Chevy C20 Longbed Stepside
1978 Chevy K30 Custom Deluxe
Bears63 #517476 03/15/2009 8:56 PM
I've noticed there is a dent on my cowl piece from where the door check failed,could my hinges be sprung too far?
todjob2000 #517580 03/16/2009 2:25 AM
That is entirely possible. You get those doors in a strong wind and it is amazing what kind of force they can swing back with, so I could easily believe that it could spring the hinges. Add in the fact that the door is constantly opening too far (if the door check is still bad) and it could have caused problems with the hinges.
