| | | Forums66 Topics128,012 Posts1,055,315 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 175 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 175 | I'm having problems with my 66 gmc doors shutting all the way, I have adjusted the latch and door striker again and again but the door will either bounce back and not shut or latch too loose and not be flush, anybody have this problem or is there a usual suspect to fix or change? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | if you've recently installed new rubber seals, I'd suspect they're not a good match for original thickness and material - also might try adusting from the hinge side as well as the latch side, the doors may be in too far there
Bill | | | | | Joined: Oct 2008 Posts: 321 'Bolter | | 'Bolter Joined: Oct 2008 Posts: 321 | I have seen lots of these trucks have these same door issues, even without replacing the seals. I am going through this with the left door of my '63 right now. If I come across the ultimate fix I'll be sure to post it.
1963 Chevy C20 Longbed Stepside 1978 Chevy K30 Custom Deluxe
| | | | | Joined: Jan 2009 Posts: 175 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 175 | I've noticed there is a dent on my cowl piece from where the door check failed,could my hinges be sprung too far? | | | | | Joined: Oct 2008 Posts: 321 'Bolter | | 'Bolter Joined: Oct 2008 Posts: 321 | That is entirely possible. You get those doors in a strong wind and it is amazing what kind of force they can swing back with, so I could easily believe that it could spring the hinges. Add in the fact that the door is constantly opening too far (if the door check is still bad) and it could have caused problems with the hinges.
